Engine harness
Plug and Play? I guess they are but according to the diagrams I am looking at, there are six separate wiring harnesses in the engine compartment of a 1996 LS400. Do you have a particular problem?
The harness that runs along the driver side wheel well. I was rubbing and broke through the clips that held it up and rubbed through the some of the insulation of the wires. ( i know i should have tucked it, but couldn't figure out how to)
There are a couplpe of 96's around me that are being parted out and was just seeing if i could buy the harness from them and put it on my car.
BahHumBug
ah, that's the primary harness from the fusebox into the car. No, it isn't a simple "plug and play" at all since it goes fairly deep into the dash.
Best bet is to just have it repaired by a competent auto electrician if you aren't comfortable with a fair bit of soldering and wire repair.
Guess i'll just have to go with the soldering route.
Thanks for the response
Do you have any recommendations on what would be the easiest way to tuck the wires higher? I raised my car up already, but it still rubs on the wire loom on right turns and big dips.
esco2114
SC- 1st Gen (1992-2000)
04-20-11 11:02 PM
toyotasrfu
09-03-07 07:23 AM
