new struts and springs
i finally started ordering parts for my ls400. i went along and started off with new front and rear kyb gr-2 struts and tanabe df210 springs. i dont know the offset of my 19 inch wheels since they came with the car when i bought it. im running a squared setup 19x8.5 with a 245/40/19 tire. would you guy recommend any type of spacers? or if i have to roll the fenders?
oops i should of noted that i havent installed the parts. i ordered them tonight. the picture above is the stock setup. i just was using it as a reference for a guestimate on rear spacer size.
By the looks of the picture you posted. IMO you might need to run a smaller tire. A small roll might do it in the rear, but the fronts might rub with those tires. But at the same time, I'm not really sure how low those springs will sit. You might have to just install them and plan on rolling if they rub afterwards....
ill try to snag some better photos of the fenders in the morning. im also gunna look for a local fender roller in my area. might as well get that done.
the thing is now that im wondering if i should just bite the bullet little and shell out an additional $212 for some megan lps. i planned on getting my fenders rolled anyways. hmm...
Super Moderator
If you can be satisfied at a fixed ride height the KYB and springs is fine. For the slight $ difference for the Megan's, it is the better choice IMO. Just to note, that due to the weight differences at the corners, the car will vary side to side in ride height. For some that can be pretty irritating and is not an issue with adjustable coils installed.
im sure ill be satisfied with a fixed ride height, but then what comes to mind is what if i dont like the height after it settles. plus i kinda do want a more sporty feeling. so i think im going to just cancel my strut and spring order and order the megans. now i just have to find a local shop thatll do installation, setup, and fender roll.
I don't have anything against a fixed ride height. BUT when you have an option to adjust where you like it, for not much more.....
I went from a stock set-up to coilovers, and I'm so glad that I did. You can pretty much set the height anywhere you want and have it ride smooth or firm depending on how you like. I heard/read that most people that go springs normaly end up buying coils in the end anyway.
