Size matters! - let's put a BIG oil filter on our LS!
Old 05-30-17, 09:03 AM
  #241
djamps
djamps's Avatar
Originally Posted by LScowboyLS
you engine internal temp is controlled by the thermostat, the ECU, the engine coolant temperature sensor, etc. - it will not run cooler, nor should it.
Operating oil temp is not thermostatically controlled, aside for some setups with external oil coolers where the cooler is bypassed during warmup, or an internal oil warmer which works the opposite until the engine reaches temperature.
Higher oil capacity generally can and will lower oil temps in extreme conditions, but I doubt the difference in filter size is enough.
Lavrishevo
08-13-15 10:42 PM
UNCNOR
07-22-13 07:20 AM
itgrowsind
10-27-06 11:35 AM
vp911
RX - 1st Gen (1999-2003)
10-24-05 01:55 PM
Quick Reply: Size matters! - let's put a BIG oil filter on our LS!
