recomended aftermarket upper control arms?
Old 05-29-13, 10:28 AM
Lavrishevo
Lavrishevo's Avatar
Default Recomended aftermarket upper control arms?
I am in the process of acquiring the parts needed to finish my suspension work. I already have the rear carrier axle bushes.
My plan is to use the ROCA urethane lower control arm bushing set and replace the whole upper control arm. Lexus wants $422 each for the uppers, which is crazy.
I am thinking Meyle or Beck/Arnley. Does anyone have any experience with these parts or recommendations?
Old 05-29-13, 10:46 AM
dengman
dengman's Avatar
beck/arnley is what im planning to use for UCA... I need to go through my lower control arm bushings and rear trailing arm i think. Felt some side to side shifting over bumps..
Old 05-29-13, 11:10 AM
Lavrishevo
Lavrishevo's Avatar
Yeah, my lateral movement became more pronounced when I lowered the car. I purchased a set of Adus bushings off ebay. To my knowledge, the ROCA bushings are the only ones that make a urethane set for the front lower. Don't want poly up front.
Old 05-29-13, 11:21 AM
j2b4o
j2b4o's Avatar
What year?
I have tried the B/A and the doorman (both currently on the car) on my 90'. The beck had no stop on the taper for the ball joint and looked a bit beat up. The castle nut also had no flare like the OEM and required a washer to be fully tightened. The doorman looked exactly like the OEM and had the stop on the ball joint taper and the flare on the castle nut and did not require a washer. Both have been fine for ~20k miles.
Old 05-29-13, 11:33 AM
Lavrishevo
Lavrishevo's Avatar
Originally Posted by j2b4o
What year?
1999. In my signature.
The reviews for Meyle arms seem to be good. They are a German distribution company. Don't know who actually makes the arm though.
Other options are, Moog, Ac-delco, Raybestos, Mevotech, Dorman, Arnott, and Karlyn,
Old 05-29-13, 12:19 PM
j2b4o
j2b4o's Avatar
I would have happily bought Moog if it was offered for my year. Have used moog parts for years and never been disappointed. Raybestos is a fairly respectable name also. I would avoid Arnott like the plague, several first gen guys tried them and they were failing like crazy.
(Sig's don't come up with the mobile site, always good to post year)
Old 05-29-13, 01:23 PM
Lavrishevo
Lavrishevo's Avatar
Do you know if the spring and strut need to come out to replace the upper control arm?
Old 05-29-13, 02:14 PM
YoshiMan
YoshiMan's Avatar
When i bought my LS400 I was in a bind and needed to replace my left control arm before taking her to california several days later. The only place that had a control arm immerdiately in stock was NAPA, and it was their in house brand "ultra-8" whatever the hell that is, however, I have had zero issues with it and it got rid of ALL of the play i had in that side. If i were to do it again, i would use MOOG as i also have had good luck with them is the past as well.
Old 05-30-13, 09:20 AM
Twista4004
Twista4004's Avatar
So it looks like Moog and Dorman are the top recommendations.
Old 05-30-13, 10:18 AM
Lavrishevo
Lavrishevo's Avatar
I'm thinking about tackling this job myself as the labor quotes are rather expensive. Can anyone share their experiences or maybe have a pdf of the procedure?
Old 05-30-13, 04:28 PM
sha4000
sha4000's Avatar
Here you go, I'm pretty sure you can figure the rest out,
Old 05-30-13, 04:51 PM
YoshiMan
YoshiMan's Avatar
It's relatively simple, but it does require that you remove the strut and spring, which isnt really difficult either. you will likely need an alignment afterwards as well, as anytime you screw with the suspension/steering, it will be off.
Basically involves pulling the tire, using a puller (a $14 one from any parts store will work perfect) to disconnect the steering knuckle from the upper control arm, unbolting the lower strut bolt, then the top 3 nuts, and sliding it out, then you can unbolt the two bolts holding the upper control arm in.
Make sure you secure the steering knuckle with a peice of wire or something to keep excess strain off the lower ball joint and some of the other parts.
Old 05-30-13, 06:11 PM
johnnyg66
johnnyg66's Avatar
Yeah, I have had my Arnotts for 2 years now put about 20k on them. Knock on wood. May go Dorman next.
Old 05-31-13, 01:10 PM
j2b4o
j2b4o's Avatar
Maybe they fixed the QC issues. That would be very nice considering you can get a pair for like 150$.
Keep us updated on how they hold up.
Old 05-31-13, 10:07 PM
johnnyg66
johnnyg66's Avatar
Will Do. Hope they last till my struts need replacing.
Quick Reply: recomended aftermarket upper control arms?
