92 LS400 Trac Off and Engine Lights
Old 05-29-13, 04:47 PM
dale1lexus
dale1lexus's Avatar
Default 92 LS400 Trac Off and Engine Lights
Hi Forums I have a 92 LS400 with 138k miles. It runs and drives 100%. But about 1k miles ago the trac off and engine light showed up on my way home. So I checked the engine light and it is code 25 (air-fuel ratio lean malfunction). So i cleared the lights by disconnecting the fuse under the hood. They both came back on the next day. So then i tried changing the MAF, cleared the lights. After an hour of driving same thing lights came back on. I heard something about oxygen sensors but i want to be sure, any ideas?
Old 05-30-13, 09:11 AM
Crybicki
Crybicki's Avatar
As you can see, I have the same problem.
This is the post on my car, if you are interested.
https://www.clublexus.com/forums/ls4...-problems.html
Any help on this traction control issue would be appreciated!
Old 06-05-13, 01:36 PM
Crybicki
Crybicki's Avatar
Just bringing this post back to life to see if anyone has any input at all. TRAC system errors are tough to figure out. Will be doing a diagnostic on mine later today though so I will share my findings here.
Old 06-05-13, 08:12 PM
LScowboyLS
LScowboyLS's Avatar
have you guys followed the step by step troubleshooting procedures in the factory service manual under that CEL code?
Old 06-06-13, 03:17 PM
Crybicki
Crybicki's Avatar
I haven't, no. I don't have an owners manual.
Old 06-06-13, 03:41 PM
LScowboyLS
LScowboyLS's Avatar
if you don't have the factory service manual, you can get a membership to Toyota Technical Information System for $15 and have 2-3 days to look at the appropriate section
JE5TR
12-06-10 05:40 PM
my92ls
01-06-09 10:16 PM
MazenSC400
Performance & Maintenance
09-04-05 12:39 PM
Brucelex
12-02-04 05:53 AM
azari
05-11-04 11:12 PM
Quick Reply: 92 LS400 Trac Off and Engine Lights
