HELP...my 97LS is smoking-a lot!!!!
Started the car this AM and smelled gas.Ran a few errands and didn't smell any more gas.Tonight, started the car and smelled gas and a lot of white smoke was coming from both exhaust pipes.Please give me some advice so I can have an idea of what is going on when I take it to the shop in the morning.Would greatly appreciate any and all comments Thank you.
● whitish gray smoke is typically coolant (head gasket, crack in block or head, water in the fuel, etc.)
● blueish gray smoke is usually oil (piston ring blow-by, PS fluid leaking into vacuum system, PCV valve, valve stem seals, etc.)
● black smoke is usually fuel (rich condition)
LexieLS
07-17-06 08:58 AM
