RPM Gauge - Works/Doesn't Work
Old 12-29-16, 05:22 PM
Yamae
Yamae's Avatar
Originally Posted by lanmandan
I recently purchased a 2002 IS300 Sport Cross. Everything was working on the car until this morning. The tachometer, MPG not working and the oil level light, and rear bulb indicator were on. What changed. Well here is what I found out. I had plugged in a USB phone charger to my cigarette lighter to charge my phone and started having the issues. Take out the USB phone charger and all issues go away. Weird but I can replicate the issue.
How does the cigar lighter have anything to do with the tachometer or any of these other dash issues?
Your USB phone charger must be causing the problem called EMI. Your charger must be sending back too much switching noise pulse to the +B line.
You'd better use a good quality one or add a good EMI filter if you are familiar to it.
Old 06-06-22, 12:57 PM
leirazepol
8th Gear
leirazepol's Avatar
Hello All,
My case is kind of tricky. If anyone can give me a hand I'll appreciate it.
The case is my 2001 RX300, I removed the cluster to confirm the size of the instrument gauges to by and replace them. I noticed that apparently past Owner made some jumpers in the circuit board, but in my interpretation this was because they've just wanted to jump some bulbs so buyer doesn't detects from start alarm signals in the instrument cluster (common practice in the D.R.). So I removed the jumpers and now my RPM and speedometer are just 270 degrees, I mean pointing gravitationally down. They doesn't even move at all.
Could it be possible that the jumpers are fixing this issue or it was just that I damaged something else once I removed it to check damaged bulbs.
Attached you may find some images.
Buhrt
10-25-16 03:59 PM
mclarenf1k
Performance & Maintenance
02-24-10 10:26 AM
2fastek
SC- 1st Gen (1992-2000)
10-21-09 05:57 PM
jdmjzz30
13
10-12-09 05:04 PM
redhanded7
12-10-07 10:26 PM
Quick Reply: RPM Gauge - Works/Doesn't Work
