Tail light brake light dead
So here's the problem:
Lights off : I step on brake pedal = Light comes ON on outter top right brake lights (fender lights)
Lights on : I step on brake pedal = Light goes completely OFF both tail light and brake lights (if I let go, the tail light goes ON)
My right trunk brake light doesnt work but tail light stays on when I have the light switch on.
Here's what I have already done based on searching:
Replaced the bulbs
Checked the harness/socket
Solder the bulbs contact fillament to make sure it touches the socket contact
Replaced the socket
Unfortunately, nothing works.
Checked the relays in the engine bay but couldnt figure it out
Is there anything im missing here?
Replaced the bulbs
Replaced the socket
Yes, if your car is a 94 or older, you likely have broken wires in your driver's side trunk hinge (common issue) and the precise location is normally in the"curve" of the hinge - open that wire bundle carefully and inspect - restrip, retwist, then solder as necessary - use heat shrink for a professional repair, or have someone good at this type of repair do it.
also to add..theres a box on the left hand side of the trunk by ur amp, that's got something to do with ur rear lights as well,im not saying its the cause,but if all ur wires are in tact on the hinge..then u can check power in and out of that box
Thank you guys for the input ! I will reply back here if I manage to solve the problem
The problem I have is on the passenger side. Is there 1 on the passenger side or its connected together from the driver side?
Is this 1 close to the factory CD changer? I am not familiar where the amp is lol
So I am guessing doing both of these would require me to take the whole cover of the trunk out to access these?
Thanks again guys !
Thanks again guys !
Thanks PD.
Unfortunately I havent check this problem yet as my coilovers just came in and was a busy day picking it up yesterday! Will try to work on this today and report back tomorrow hopefully !
SethP
RX - 1st Gen (1999-2003)
12-20-09 09:04 AM
STR
01-13-09 12:07 PM
pitmanr200
09-16-08 09:32 PM
beels1
03-21-04 08:05 AM
