Rear Brake Pad Replacement
Im finally going to be working on my brakes for the first time since i was finally able to get all the correct tools. ill be replacing the rear brake pads with some centric posi quiet ceramic pads with shims and hardware kit. i have a few questions before i start and i just want to be sure im doing it correctly. i had to get a new fitting kit according to my buddy who installed my rotors for me. since the posi quiet pads come with the shims and hardware. i know i wont have to order a shim kit, but does the hardware included with the pads the same thing as a fitting kit? or would i still have to order the fitting kit from lexus? when installing the pads would i need to apply any type of brake grease to the pads? or just the shims alone? and lastly prior to even starting the pad replacement. would i have to bleed the brakes? if not what steps do i have to do in regards to the brake fluid? or do i just take some out of the reservoir under the hood, then add if needed?
Break grease is optional. Most people will use it. If your new pads come with shim kit than you don't need to order any from Lexus.
See this for more help if you haven't seen it already.
http://www.lexls.com/tutorials/brake/rbpad.html
it sounds like you dont have a clue as to what you are doing, so I suggest you get your buddy to show you HOW the first time, yours and someones life may depend on your brakes.... that is a bad place to start your DIY training.
yeah i havent done any brake jobs for over several years since i took auto shop in high school. i just wanted some clarification on how to do it correctly. suspension is just one of those things i havent worked on yet. my buddy will definitely be there to help me out. i was just confused with the fitting kit from lexus compared to centric saying it includes a hardwire kit. i also just downloaded the factory repair manual. so ill read over that prior to tackling the job.
so i removed the lug nuts and the wheels. and noticed that my rear rotors dont have the screw to hold the rotor in place. are this screws necessary?
There are many things in life and on your car to worry about. These small screws are not one of them. Many cars do not even have them. The best I can tell is they hold the rotor in place while the wheel is off (they stay in place most of the time on their own) so they don't flop around as you are working . When the wheel is on your 5 lug nuts hold the rotor in place---not those tiny soft screws. If you lost a wheel as you are traveling down the road, those screws are NOT going to hold the rotor in place, and it wouldn't make much difference if they did. Most people will say "Lexus put them there for a reason" so they will insist you would be crazy to operate your car without them. Believe me, there is ZERO danger driving your car without these screws.
I had the same question as OP when I changed my rotors for the first time. From what I have read and heard is that those screws were only put in to hold the rotor on during the assembly process. Most people just take them out and never put them back in. My car does not have those screws on any of the rotors and it is 100% fine.
once you are done pump the brakes a couple times before you move the car. this will seat the pads against the rotor where they are supposed to be instead of having to move all the way in the first time you try to brake.
