need light blub source
Old 07-15-13, 06:26 PM
mbz560
mbz560's Avatar
Default need light blub source
looking for climate control blubs part # 83119 24530 need 3 of them
and # 83119 24490 need 4 of them
i went to the dealership and they want 7 dollars for each !
any suggestions. thanks for the help
Old 07-15-13, 06:27 PM
mbz560
mbz560's Avatar
Default forgot to mention 92 ls400
Old 07-15-13, 06:41 PM
LScowboyLS
LScowboyLS's Avatar
we need the numbers off of the bulbs (not the Toyota part number) in order to find you a deal on them
Old 07-15-13, 06:51 PM
mbz560
mbz560's Avatar
i know what you mean about the number but there are no numbers on the blub. they are super tiny and the bulbs are like wired into their rubber holders all i could find on the rubber that holds the bulb is TSD and V5. i think...i could barely read them. anyway, they illuminate the climate control there are 3 black ones and 4 grey ones. thanks for the help
Old 07-15-13, 07:02 PM
LScowboyLS
LScowboyLS's Avatar
some ideas for you
Old 07-17-13, 12:35 AM
j5ive
j5ive's Avatar
I can't remember if I found the info on this forum or elsewhere, but you can actually purchase these bulbs from Radio Shack and replace the burnt out bulbs by unwinding the legs from the plastic base, then wind the new bulbs's legs around the base as before and snip off the excess. I just did this with my headlight washer switch light (same as TRAC OFF button and Seat Heater Buttons)
Hope this helps. Good Luck
Old 07-17-13, 02:03 PM
mbz560
mbz560's Avatar
outstanding ! i did that this morning i.e. taking off the wire. and i was wondering where i was going to get the bulbs. thanks for the link.
Old 07-17-13, 04:54 PM
billydpowe
billydpowe's Avatar
I found these somewhere:
1999 Lexus LS400 Car Light Bulb Socket Sizes
Low Beam Headlight Bulb Size: 9006
High Beam Headlight Bulb Size: 9005
Parking Light Bulb Size: 2825
Front Turn Signal Light Bulb Size: 7440
Rear Turn Signal Light Bulb Size: 7440
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: 921
Fog/Driving Light Bulb Size: 9006
License Plate Light Bulb Size: 2825
Back Up Light Bulb Size: 7440
Front Side Marker Light Bulb Size: 2825
Rear Side Marker Light Bulb Size: 2825
Glove Box Light Bulb Size: 37
Step/Courtesy Light Bulb Size: 194 or 74 or DE3021
Trunk/Cargo Area Light Bulb Size: 194
Instrument-General Light Bulb Size: 194
tomstep2
02-22-15 04:44 AM
Vadim540i
SC- 1st Gen (1992-2000)
05-21-10 08:19 PM
NCDUB
03-28-09 10:15 AM
dbullen
11-03-03 07:47 PM
skpark70
03-28-03 07:49 PM
Quick Reply: need light blub source
