changing stock air shocks
Anyway, my shocks got sent to Ohio instead of Ct. so I wont be doing them this weekend. I'll keep it updated incase anyone is following this.
Got my shocks in yesterday. After talking to the company to tell them they were sent to the wrong state, they overnighted me another set. Great customer relations.
In the process of changing them now. Everything came off nice except the swaybar link. I didn't know ya had to use an Allen wrench in the head of the link. I shoulda read my manual, oh well. I just kept turning it and the grease came out so now I gotta get another one. Also, I need to drill the holes at the top just a tiny bit so the shock fits up inside.
You shouldn't have had to remove the link to intstall or remove the shocks. The top bolt holes are tight and need to be approached at exactly the right angle, I wouldn't recomend drilling them larger.
One more question, b/c I never changed shocks before. When it's all bolted up top, it's not gonna be lined up for the bottom bolt, is it ok to turn the bottom of the shock to line up with the bracket? I just dont want to screw up the new shocks.
I got the passenger side in. (with trouble) The drivers side is bolted in the top but I can't get the bottom to turn so I can get it in the bracket to bolt it. It's like 10* off, it wont turn.
What is the bolt in the center of the top of the shock? I see in the manual it says to loosen that, but it doesn't say why. That's also for a stock shock. Anyone know anything that would help me? Like I said I never dealt with shocks.
Oh, I didn't need to drill the holes wider or use a spring compressor like I mentioned before.
The top bolt holds the shock in the mount(the piece that bolts to the car). If you loosen it it should allow the shock body to rotate. Are you sure that if you spin the shock assembly around so the top bolts are in a different position? It may make the bottom bolt line up in one position. You could also stick a big screw driver in the bottom hole and use it for leverage to turn the shock body.
Is there a certain torque that nut should be when I tighten it back up?
Done. I got the shock to turn enough to get the bolt through the holes and tightened it up. Took it for a ride and it rides just ok, not great. It feels like a total different car, like nothing I've ever driven before, maybe b/c the fronts are springs and the backs are still air, til I can afford those. The guy at the Lexus service dept. was right, "the *** end wants to kick out a little" but only when I hit a dip going around a curve at speed on the highway.
I did realize I need both UCAs worse then I thought. I knew the ball joints were bad but, man, I could blow on the ball joint and it would move, I've never seen something so loose. (and my X-wife had 3 kids)
I guess that's a job for another weekend. Any suggestions on aftermarket? (I'm gonna search to see what is out there) On lexls he says to take out the shock to get the UCA, does it have to come out? It didn't look like it to me.
Just an update on how it feels and rides after a few days and a couple hundred miles. The back doesn't want to kick out anymore. (or maybe I'm just used to it now) I don't feel any bumps in the front with the new shocks/springs, which is how it should be. The back, which is still air, bounces ALOT. (like a car with bad springs) It feels like I'm in the ocean hitting some big waves in a tiny boat. Also, the rear of the car looks like it's sitting way high, like there's too much air in them. My guess would be that the air suspension ECU cant adjust only the rears good enough to smooth it out. I'll just have to live with it for now, til I can change the rears to springs. The Height light on the dash flashes (no big deal) even though I unplugged the front height sensors. Actually I pulled those off and for sale if anyone needs them.
time for the backs already
Well, I guess the backs didn't last much longer. After changing just the front shocks from air to springs it was going good. But Fri. morning the back right was really high. (never that high, ever) I went out a couple hours later, to put windows up, b/c of rain. The back right was low, almost on the ground. It usually did this when it was hot and humid out so that's what I thought it was. Most of the time it would fill up when I started it, but not this time. The compressor wont kick on by itself. I can turn it on from jumping the connecter at the ECU in the trunk but it wont blow it up.
I'm just so tired of the air suspension in this car I'm changing the rears over this weekend and be done with it. All the good air parts will be in the classified section soon if anyone needs them.
These are what I went with. So far the fronts feel good, will have the rear in soon and will post how it rides.
Front
http://www.justsuspension.com/catalo...sembly-61330c/
Rear
http://www.ebay.com/itm/Pair-Rear-Air-Bag-to-Coil-Spring-Strut-Conversion-Kit-for-a-Lexus-LS400/350770922522?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D890212812544195642%26pid%3D100033%26prg%3D1011%26rk%3D1%26rkt%3D4%26sd%3D350770922522%26
You do not need to remove the springs to change the control arms. All you need to do is possibly compress the spring while it is in.
1.-I had the car lifted with my jack
2.-Put a jackstand somewhere under the lower control arm or ball joint.
3.-Slowly lower the car and the pressure will compress the spring.
The bolts that attach the upper control arm are long and the spring may get in the way while trying to remove them.
The spring may or may not be in the way while trying to get those 2 bolts out. If they are that is the process that worked for me.
I'm doing the rear shocks/springs now and I can see why the manual and the dealer says the driveshaft/axle needs to come out. Even with pushing down on the whole assembly, like PureDrifter and others have suggested, I cant get enough room to get the bottom of the shock by the driveshaft and into the mount. I'm now gonna try to compress the spring to see if that will help, I hope so.
Finished, finally. I needed to compress the spring to get the lower part of the shock up into the bracket. I think the hardest time I had was installing the top of the rear seat. I couldn't get the center to hook on. It took alot of pushing, pulling, and banging but it finally went in. (After an hour, and a gallon of sweat) It doesn't ride anywhere near as good as the air did but at least now I don't have to worry about other air related parts breaking. That is worth all the struggles I had and ALL the pain I'm in.
Jonx
05-06-20 07:12 PM
chemical44
GX - 1st Gen (2003-2009)
03-15-10 12:32 PM
