changing stock air shocks
I had a front shock blow out just sitting in my driveway. Went out the other day and the left front was sitting down ON the tire. I thought it would inflate when I started the car like the back did whenever that went down. But, it just dripped out grease. I've searched for a few days and I can't find one used air shock.
Anyway, I have a question about the conversion kits that are out there. Can I do the conversion on just the front for now? (Until I can afford the back) Will the back still fill with air? What do I do with the front air lines? I dont care about the lights coming on the dash, that wont bother me. I just need to be able to drive the car.
I can't post the link for the kit but it's on ebay, item # 190826690648 It says all the years but then "except for auto leveling". But if ya unhook the sensors, wouldn't that be ok?
I'm just looking for the very CHEAPest fix right now, even if it's only good for a month or so.
reference:
https://www.clublexus.com/forums/ls4...ir-struts.html
the air hose is an actual fitting with a hardline attached to it, much like a brakeline. if you have a true leak the cheapest fix would be to find the leak and try to remedy it rather than convert to traditional spring/shocks. if you have grease leaking, it may be the shock itself and not the bellow (bag).
I would got to a junk yard/pick n pull and grab some used shocks. Grab the whole assembly from mount to shock and swap it over. If that's not your bag I think siensen or some company with a similar name makes ultra cheapies for like 200$ for all four corners.
Hey timmy, thanks for that reference. I have the manual but pics and first hand experience is always better. The day this happened, when the car was running, I heard air spraying out and saw grease on the ground. It was real thin, like oil. This air susp sucks, no junkyard around here can even find one of these shocks. If I do convert it, can I just cap the air lines? Will that mess up the susp ECU? I'm trying to get all the info I can b/c the place I'm staying doesn't allow ya to work on vehicles so I'd have to do it all real quick and in one shot.
Thanks for the help.
Thanks but that's just about bump stops and stuff.
I just need to know if I can convert JUST the front and what to do with the air lines. I've been searching and reading for a couple days and haven't found my answers. I'm laid off again so I got time to look and read but I hate not having a car to drive. I wish I had more cash flow so I wouldn't have to worry about any of this. Something always breaks at the worst possible time for me.
Thanks again for the help. Any and ALL is appreciated.
Yea, car-part.com is always the first choice. A few postings for shocks. I called and none are air.
I was thinking, can I just pull the fuse for the suspension b/c the backs are already filled with air.
Would the shocks release air out the release valve if the fuse is out? Wouldn't want that to happen. Whatever I do, it wont be done til next week so I'm just trying to get whatever info I can. I'm being a sponge, absorb everything.
If you pull the fuse the rears will stay inflated as long as they can hold the air. However I would suggest that since the front has gone the rear is likely close behind. The rear likely leaks also, just at a much slower rate. With the system engaged it is able to compensate and re fill the bags as needed. Once you pull the fuse I wouldn't expect more than a few days of inflation.
I always said once 1 goes I would convert the whole system. But, the cash isn't there now. My budget is only a couple hundred, so that's either 1 air or just front conversion. The car has been sitting for a week and the backs are still the same height so I don't think they leak. That's not to say that they wont in the future.
Thanks for the input.
Well, I think I got my info I needed. I called the dealer and they said they always do all 4 corners, not just the front. But, he said just fronts can be done but the ***-end will want to kick out b/c its on air. What?? Whatever, see what happens. As for the front air lines, I was told to just unplug the sensors. Shocks are coming in Thurs. so I should be putting them in this weekend. $177 shipped for the front 2. That's half of 1 used air shock on ebay so I think I found my CHEAPest way.
I called some of the biggest junkyards in the US and found nothing. I want to eventually go all airless anyway.
I'll let you know how it turns out.
