One heck of a day!
Here the ball joint and the part number. Hopefully you can read the tag? He also said he can get me the strut rod bushings for $120 each, which is about$30-40 cheaper than Sewell!
and I think you mean entire strut bars, not strut bar bushings, which are very inexpensive
I'm refering to these. He called them radious arm bushings, but I know them as strut rod bushings. Unless of course I'm wrong?
I have only found them for around $80-100 each, but for off brands?
I might be wrong but I'm pretty sure these are whats popping in my front end when turning.
So far I've replaced
:stock struts with coils
:lower ball joints
Need to replace
:tie rods
:strut rod bushings?
: upper control arms or just the bushings
: end links
:lower ball joints
Need to replace
:tie rods
: end links
I cant confirm that at the moment. I'll ask him this coming week what the part number is.
With the discount on Sewell, the part is $144.81. So if he can get me the same part for $120, I'll be happy with that knowing they are OEM parts.
Here's the part # on Sewell
48674
4867450030
STRUT BAR CUSHION
48674
4867450030
STRUT BAR CUSHION
Not familiar with a '93, but those "bushings" you show look much like the upper support mounts at the top of the strut tower. Those would definitely NOT be the same as the Strut Rod Bushings, and suspension knocks are almost always caused by worn out SRBs. They are basically a sacrificial component of the cushy LS ride (good for ~50K miles); the rest of the suspension components are much more durable.
Bushings you can buy but I think they're a pain to put in. http://www.lexls.com/tutorials/suspe...aizenkit2.html And for what it's gonna cost, ya might as well get new UCAs b/c the ball joint is probably bad also.
When I was browsing the net the other day looking at parts. I thought for sure I found a couple different sites selling the whole upper control arms? I know they were not the OEM ones but I thought those could work?
there are a lot of threads on here of people trying different aftermarket upper control arms in order to save money, most of the time, it does not turn out well, but there may be a good one out there, just do a lot of reading on here!
