of my LS400 tranny is acting VERY weird! (UCF20/21)
before I start with the story, let me inform you that the car has stored in the garage for 2 years. never started it until last month and done a major service which cost me $2000 to fix stuff!
the main problem here is the transmission, it was fine for a while after it was serviced, but now when I shift it to "D" it moves like the clutch was done for, but later I discovered that it doesn't shift to the 1st gear for some reason until I shift to "L"! checked the tranny fluid and it was okay "darkish pink" dunno of that makes difference
I personally suspect the critical point lies within the electricity, because when driving for like 30 mins the ECT PWR start flashing even though when it's not in use. not to mention the shift lock clicks a lot when shifting to "R".
hopefully I can get answers.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
when my transmission had these exact symptoms, after much tearing out of my hair, the culprit turned out to be failing ECU capacitors
makes sense though, as the ECU is responsible for shifting and transmission control
I mean, will this work?
Welcome to Club Lexus.
So that we have a bit of background, what items were part of the major service?
please read my thread linked to, to see how to fix the capacitors
OBD ports do not "go dead" on an LS400, if you are not getting any response from the OBD port, this is a classic symptom of failing ECU capacitors
please read my thread linked to, to see how to fix the capacitors![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I'll try the re-cap option, I'm sure the new one cost an arm and leg (1998 Mercedes E300 cost around $2000)
yes! CEL go off when starting, but it appears randomly at times.
there's one at the junkyard nearby that sells the Japanese model "Toyota Celsior" ECU. excat same year model, you think that'll work?
Celsior ECU is different than LS400 ECU, even different years of LS400 ECU are typically not interchangeable, besides, a junkyard ECU would also need its capacitors replaced, so that doesn't really help you!
be sure to use the exact capacitors I have linked to, they are a special and rare type.
any other brands or series of of capacitors, and I cannot promise that your ECU issues will be solved!
