Need help with my Timing Belt shopping list...
Bosch is the inventor of ABS and the pioneer of fuel injection.
So if anyone has a good source for Aisin TB kit, somewhere on the west coast or in California, and that is at right price and willing to ship today for, say, Monday, please share. Otherwise, I can only pray that this thing makes it here on Monday as it should (the Fedex site is already saying "estimated delivery - Wednesday or Thursday").
peterls - if you haven't done a timing belt on an LS400 before, or even if you have, I strongly recommend you watch this video first, in its entirety!
Nick Stageberg, an amateur, does his first timing belt, on an LS430 (pretty much identical procedure to LS400) and surprisingly, he does a damn good job, except for not using a torque wrench for reassembly, but still very impressive for a beginner!
If you do yours this well then you will have us all impressed!
I just checked the timeline on fedex tracking: I ordered the TB kit from them on Thursday morning. They called fedex to pick up at 7pm on Thursday evening. Fedex picked up on Friday at 3pm, by which time many things that I ordered on amazon, AFTER the TB kit, already arrived (!). Now, Saturday, my package is on the truck, coming from Arizona, which is not that far, so theoretically it could arrive on Monday, had it not been for the USPS deal where Fedex will deliver to them first...
BTW, the seller on Amazon is "Car Part Kings" and I am unimpressed. I am supposed to drive on Thursday, so if I get the package on Tuesday evening (fingers crossed) then I have only Wednesday to make sure I do it all perfectly well.
Just hoping for some luck with removing that Crankshaft pulley bolt...
BTW, are the threads on it opposite, meaning it unscrews to the right?
I just wish I saw your post earlier, now it is probably too late to order (Saturday evening).
you need to borrow a portable compressor and use that 1/2" impact I recommended, other methods are rather squirrelly
especially the "starter bump" method, with our precarious starters
the 4 foot or longer breaker bar will work in a pinch
Robert Bosch, a relative of mine, and his famous Stuttgart firm, was the inventor of diesel fuel injection, as well as O2 sensors and indeed a pioneer of many things including traction control, magneto ignition, spark plugs, windshield wipers and lots of other cool systems we depend on every day, but not even close to being the first with ABS, which was available from Ford, Chrysler, GM, Nissan, and Bendix by 1970-71, years before the first Bosch system.
and even though Bosch is definitely a pioneer in ignition systems as well as fuel injection, and has a lot of patents on those, ABS, and other areas that even Toyota must license, still doesn't mean their aftermarket division builds a cap and rotor that fits and performs in the league of Nippon Denso which was the designer and engineer and manufacturer of these systems on our LS400's, so I will be sticking with the OEM on these critical components!
or just get a '98 or newer LS400 and say goodbye to those pesky distributors, caps, plug wires and rotors!
I was just checking prices and found out that if one is patient, a newer LS can be found for not too much money. For instance, I just found a 2003 LS430 for $9000. And it was in perfect condition, except I had no money to buy it...
??? about terminology
This is a great thread for this procedure on an older LS400 but I am confused a bit...on my 98 is there a timing belt, a serpentine belt, and a drive belt or are these terms interchangeable for the same belt? Noob question, but on a recent stealership oil change they mentioned the serpentine belt "should" be replaced soon. Thanks. Hiroshi
There are two belts:
1. Timing Belt
2. Serpentine Belt = Drive Belt = Accessory Belt, etc.
Dang! Caught again in the time warp :-)
1. Timing Belt
The drive belt is another term for the serpentine belt. The serpentine belt is what runs on all the pulleys for A/C, PS, alt., fan, etc. I wouldn't take a chance with the serp belt, change it if it looks bad. You can still drive the car if it does snap (just to get home) as long as you remove the broken belt.
