Help please: reset the brake Light sensor in ,94 LS400
Old 01-16-03, 05:11 AM
Maeve
Maeve's Avatar
Post Help please: reset the brake Light sensor in ,94 LS400
Hi guys,
does anybody know how to reset the brake light on the dasboard? I just replaced the brakes and one of the brake sensor (rear right).
Thanks for the help.
Dominic
Old 01-16-03, 01:15 PM
damon
damon's Avatar
Default Pad wear light
Dominic,
The Lexus Dealer method is to charge you $110 per wheel for a new sensor (un-installed price) and send you on down the road.
Apparently there have been people here who have had success repairing the old sensors by adding a layer of solder to restore a closed circuit. Upon contact , the solder will wear thru breaking contact & cause the warning light to function just like the originals.
My conundrum is that I have disconnected the sensor leads & closed the circuit with a jumper , proceeded to disconnect & then reconnect the battery & I still have the damn light!!!
I have an inspection coming up & am about to pull the damn bulb!!
perplexed in Dallas, damon
Old 01-16-03, 04:09 PM
GA400
GA400's Avatar
Default Re: Pad wear light
Originally posted by damon
Dominic,
Damon,
Is it the same dash warning light for tail light bulbs and wear sensors (If I remember right on my 91 LS, it is a red light that says (Brake!)? If so, you may have a bulb that is burned out rather than a wear sensor problem, mine was coming on intermittently until I took all my bulbs out, cleaned the contacts, and reseated them.
Hope that helps,
Ga400
sumrtoy
09-30-22 03:23 AM
Michael
11-13-13 07:49 PM
topgun129
10-14-09 01:41 PM
glenn wojn
02-19-09 08:34 AM
nem364
11-26-08 11:53 PM
Quick Reply: Help please: reset the brake Light sensor in ,94 LS400
