Looking for performance suggestions, seems like a rare thing to do.
Old 09-19-13, 07:21 PM
geoprz
geoprz's Avatar
Default Looking for performance suggestions, seems like a rare thing to do.
I understand the ls400 isn't a sports car but I'm looking for more power out of the V8. What are people doing to squeeze out some horsepower? Other then a cold air intake and exhaust...
Need to replace my ECU. Are there performance tuned ECUs out there for our cars?
Old 09-19-13, 07:36 PM
Yamae
Yamae's Avatar
I know a guy who's IQ is 170. He has once tried to analyze the ECU for a Celsior.
He was ended up just modding sensor signals.
You need to be smarter than him to get more power.
Old 09-19-13, 07:46 PM
usoff89
usoff89's Avatar
For tuning you really have to use a piggyback setup or a complete standalone ecu.
They make cams for the 1uz, and you can do head work. You could always go boost on top of that stuff too! There are a lot of options really.
I hope you won the lotto though, it's a very expensive motor once you get into the internals.
Old 09-19-13, 08:59 PM
LScowboyLS
LScowboyLS's Avatar
The MINES piggyback is the only ECU mod that actually does anything, and it doesn't do a lot (and it is like $2000)
Everything else is snake-oil, but if you fix your failing ECU caps, it will give you additional low end torque that the car hasn't had in years, so that is the best way to go, unless you are rich!
it also will nearly always make all of your ECU issues go away, so the extra power is a bonus!
Old 09-19-13, 09:27 PM
RA40
Super Moderator
RA40's Avatar
My thoughts among Toyota:
2UR-GSE from the IS-F
2GR-FSE from the IS350 and GS350
It is a sin against the Toyota God, yank the 1UZ and put in a GM crate motor.
Old 09-20-13, 06:23 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
same stuff you would do on any other NA car, other than reflashing/tuning the stock ecu.
Old 09-21-13, 11:27 PM
geoprz
geoprz's Avatar
I can't even find real performance headers for the damn car
Old 09-22-13, 01:10 AM
LScowboyLS
LScowboyLS's Avatar
every Toyota vehicle I have ever installed aftermarket "performance headers" on, I have lived to later regret!
no aftermarket company seems to come close to Toyota fit and finish, and they always end up causing issues - and besides, your stock exhaust is nicely tuned from the factory, not a lot to be gained there anyway - everyone always jumps to rip out the Lexus exhaust parts, manifold, cat converters, etc., first thing, with no regard of just how finely engineered they are from the factory - just because some other cars have retarded exhaust designs that need to be trashed ASAP, don't assume your Lexus does, they did a helluva engineering job on our exhaust system, and that is the last thing on the car I would touch!
Old 09-22-13, 03:54 AM
PureDrifter
BahHumBug
uhh, PPE makes them for the 1uz, they have patterns for and have made them for '98-00 for sure.
the SC400 headers are rumored to work if you do a custom cat/y-pipe setup.
The factory exhaust is set up to be quiet and efficient and pass EPA/CARB regs for the era. Not performance. Between the FIVE (5) stock mufflers and resonators, crap merges, and log-style manifolds, there is power to be gained. The only part of the exhaust I am completely happy with would be the surprisingly high flowing and high quality metal substrate catalytic converters.
Old 09-22-13, 12:02 PM
RA40
Super Moderator
RA40's Avatar
We've hit on this years ago. Since this is in discussions, JBrady's old thread:
https://www.clublexus.com/forums/ls4...tml#post482166
Old 09-22-13, 07:01 PM
rick1987
rick1987's Avatar
From what I gathered,
There is not a whole lot of performance parts for these cars, and the stuff they have is expensive.
Its a big 4 door luxury car. Most people dont want to race these cars, so why would they make the parts?
to make more power you need to feed it more air, and get the air out. as well as the fuel.
and Im not talking a cold air intake. if you think that is going to give you bigger numbers then just go to Autozone and go nuts.
you need Cams, port and polished heads, some sort of forced induction, free flowing exhuast, stand alone ECU, more fuel.
Old 09-22-13, 07:09 PM
LScowboyLS
LScowboyLS's Avatar
if you want a smokin performance car to build, may I suggest a nice Chevy Camaro, Ford Mustang, etc.
the LS400 is all about fit & finish, reliability, quietness, and luxury. - or to sum it up in one word, the Lexus LS is about style - it's not a performance car, and not a good candidate to make into one!
Old 09-22-13, 11:38 PM
PureDrifter
BahHumBug
That may be what the LS means to you, but apparently it isn't what it means to many others
Old 09-25-13, 11:05 AM
Hiroshi12
Hiroshi12's Avatar
If by "helluva job" you mean restricted air flow with FIVE mufflers - then yes, they did a great job. Personally, that was the FIRST thing I trashed. Went from the cat back with straight pipes to two Flowmasters. A 110% improvement over stock setup, JMO.
Old 09-25-13, 05:13 PM
LScowboyLS
LScowboyLS's Avatar
you have turned a refined luxury sedan into a hopped up camaro - congratulations!
Quick Reply: Looking for performance suggestions, seems like a rare thing to do.
