97 reset immobilizer?
my 97 ls400 scraped a wire in the fender which caused my engine to shut off and my starter to not stop.
i had to unplugg the battery for it to stop. i towed it to the nearest shop and he fixed the wires and got the starter to work properly but now the engine wont start. what could be the problem?
he also checked all the fuses and they were good, the ecu is getting power but wont link with this computer.
update! i thought it was the immobilizer but found out it wasnt. got a new ecu cuz the other was fried.. should i get a new wiring harness? or get it repaird. i know nothing about electrical.. i have a 97 btw and it was the wiring in the driver fender
you need a good auto electric technician, and they are hard to find, but a good one can repair a harness with solder, splice, and heat shrink as good as new! - the only really good ones I know are in St. George, Utah & Phoenix, AZ - but there are others.
have a proper automotive electrician look at it and confirm all the wiring in the fender harness is fixed.
You may need to get a dealer to reprogram the ECU/key as the immobilizer key is supposed to be coded into the ECU. Can't confirm 100% as the '97 was an odd year as it was the only pre-vvti LS400 with an immobilizer.
better locksmiths can also do the ECU/key reprogramming/matching, but not just any locksmith, as it takes a pretty hefty investment in equipment and Toyota's Security Professional program
ededdie
10-17-15 05:32 AM
