ls400 has a knock!!!!?!!
Hey guys I bought this car a week ago. Did an oil change when I got it and today I was in a drive thru and heaard a knocking sound. Checked under the hood and it seems to be coming from the power steering resevoir/pulley area but its pretty loud. If it idles for a bit it goes away then comes back. Any suggestions on what it could be? Oil level is good. Nosmoke or anything.
in fact, while you are at it, check ALL fluid levels, as well as the serpentine belt and cooling system hoses
what kind of oil and filter did you use?
Fluid levels that need to be checked:
● Oil (use 5W-30, full synthetic preferably)
● Power Steering fluid (use Dexron III)
● Transmission fluid (use Toyota T-IV)
● Brake fluid
● Coolant (use Toyota red long-life coolant 50/50 with distilled water)
● Differential
take off the serpentine belt and see if the noise remains - this will quickly narrow it down on what is causing the noise! - you do not need to unbolt anything to remove the serpentine drive belt
if the noise disappears with the belt off, then the noise is either the belt tensioner, PS pump, A/C compressor, idler pulley, fan pulley, alternator, or the belt itself
^ It can be run longer than that without the serpentine belt. The water pump is powered by the tiiming belt. Just keep close eye on the temperature. A couple minutes is fine as long as the temp is under control. Only minor concern would be running the battery down with no charge from the alternator but the motor would probably overheat long before the battery dies.
in the rare case of a startup knock from the engine itself, such as valve train, you can use the Motorcraft FL-400S oil filter to get oil to critical areas faster on startup.
BarrettF77
RX - 3rd Gen (2010-2015)
13
05-22-13 01:48 PM
