Idle problem
Old 01-17-03 | 06:19 PM
Lvangundy
Guest
Posts: n/a
Default Idle problem
I'm getting that notorious low idle engine shake problem now.
Sometimes the RPMS drop below 600 and the shaking starts.
Even if I turn the AC on, the RPMs stay at 600 or 700.
Any clues?
I don't want it to stall so I rev it when it does that.
Old 01-17-03 | 06:41 PM
AllstarMcC's Avatar
AllstarMcC
Did you try bleeding the coolant? Most idle problems are the result of either a coolant or vacuum problem.
Old 01-20-03 | 01:41 AM
GSquicksilver's Avatar
GSquicksilver
COOLANT???
that's a first.
Old 01-23-03 | 12:22 AM
BrianV's Avatar
BrianV
My car tends to idle low, it doesn't shake really, but idles low, like under 500 at times. If I turn the AC on it goes to like 750. I can actually feel the the slightest vibration (unnoticeable 99% of the time) when the RPM's drop.
enezero
Performance & Maintenance
02-15-13 07:47 PM
DreamSC400
09-05-12 01:38 PM
Qcollons
11-08-11 05:02 PM
MQM
Performance
08-17-03 03:22 PM
hokietech
03-29-03 12:48 AM
