Timing belt water pump. Car backfiring?
never heard of it happening when a new, correct OEM timing belt and tensioner were used and the crank and cam pulleys were checked for dryness (no oily-ness in the entire timing belt area inside the covers)
you can use 91% isopropyl alcohol to make sure every pulley etc. is oil free
did you use a new, correct OEM timing belt (Bando or Mitsuboshi or Toyota) and tensioner (NTN or Toyota) ?
also rotate the crank several times before final checking of marks (always rotate clockwise when viewed from front of car)
make sure both cam pulley marks line up, most of the time when this happens, only one of the pulleys is off the mark
Bhubb18
03-03-15 01:17 AM
Och
05-15-06 08:01 PM
