1992 Lexus shaking no power
The timing mark are good the firing order is good 2 new coil spark plugs and wires I check the driver side cat was red and the passenger wasent please help
could be a lot of reasons - have you pulled the codes as shown here?
if so, clear them and drive the car and then pull them again and post the diagnostic codes you that you come up with here!
a common cause of shaking/no power problems on your year model is failing ECU capacitors but there are also other possible causes that can cause shaking/no power
andrewdees
Performance & Maintenance
01-26-09 03:11 PM
