LS400 Rear Deck Subwoofer Mounting
Old 10-29-14, 09:53 PM
  #136
Sc0pe
Sc0pe's Avatar
Originally Posted by stopdrpnro
Not having the tools or the know how to weld makes it exponentially more difficult to pull off what you did. I think I'm going to be lazy and go with trim + the 10
Not really. You can walk into a place that does welding, and have them give it a whirl. Shouldn't be too expensive, considering you'd be right up around the cost of a decent subwoofer enclosure. The benefit of Shmee's setup, is that it's modular, so you can remove the old baffle, and swap out to a different one if your setup should change.
Old 02-19-15, 11:11 PM
  #137
dengman
dengman's Avatar
wow, where have I been. I need to figure if I want to sell my 15" fosgate hx2 or try to mount it in the deck.
Old 02-23-15, 12:39 PM
  #138
LEXUSA400
LEXUSA400's Avatar
How deep is it?
My original plan to use an Acoustic Elegance SBT15 has been changed due to having to mount it from underneath the rear deck, it was too deep to drop in from the top.
New plan, 12" EarthQuake SWS-12X shallow mount. Lots easier to mount, won't have to cut much if any of the carpeted trunk liner, easier grill to make, might be able to keep the OE 3rd brake light in place........
Should give me more than enough boom, has something like 31mm of Xmax.
SHiZNiLTi
11-03-18 11:34 PM
CLUB300
09-14-12 09:06 AM
Schnitz
12
12-09-09 04:03 PM
bighitbike
01-16-08 06:27 PM
TimDimman
11-12-02 05:02 PM
Quick Reply: LS400 Rear Deck Subwoofer Mounting
