LS400 Rear Deck Subwoofer Mounting
Old 02-10-14, 06:09 PM
  #76
timmy0tool
timmy0tool's Avatar
lovely setup plans but 10gal tank is way too much! i ran 10gals on my accord wagon and there really wasn't a benefit from double the volume. you will overwork your compressors like i did. i went down to 5gals and found it to be a decent compromise. if a dual tank is desired for symmetry, run two 3gal tanks.
Old 02-10-14, 07:28 PM
  #77
Shmee
Shmee's Avatar
As far as the air tanks go, they state an "industry labeled" volume of 5 gal but claim an actual volume of 3.5 gal. Not sue if this translates across all other tanks or not... Still trying to figure that out.
Those Air zenith are by far the best, strongest, fastest compressors I have found. One of them reportedly replaces two of the viair 480 compressors for cycle and fill time on pretty much any size tank, so I'm not worried about overworking them.
Old 02-11-14, 01:55 AM
  #78
LEXUSA400
LEXUSA400's Avatar
Originally Posted by Shmee
I don't want anything in the spare tire well, except the spare tire... A leak from the trunk seal is enough to damage/destroy the components I'd mount there, and seeing as I have already had water accumulation issues there, I'm hesitant to put anything electronic in the well on this car.
Has this issue been discussed here? I haven't searched yet but I suppose it affects all of the LS400's. I'm gonna try something tomorrow and see if it stops water from getting in there. I'm gonna remove the seal and rotate it 180 degrees. It looks like the area where the water accumulates, the front corners, is also where the seal gets flattened the most, gonna put an area of the seal that is not as flattened in the front corner area. I am also considering drilling a drain hole in that area so any accumulated water can drain out like they have for the sunroof area and run the drain hoses to the same location.
Old 02-11-14, 02:57 AM
  #79
munday
munday's Avatar
https://www.clublexus.com/forums/ls4...the-trunk.html
This will fix your issues, i promise
Old 02-11-14, 08:40 AM
  #80
LEXUSA400
LEXUSA400's Avatar
Thank you.
Old 02-11-14, 09:50 PM
  #81
rick1987
rick1987's Avatar
following this thread.
I will be doing a system upgrade very soon.
Im still trying to figure out the bass, Maybe I will copy your deck method.
So far Ive picked up a pair of Hertz HSK 165 6.5 components for the front, a Pioneer AVIC 150bh, a old school Zapco 350x2 amp, and about 40 pounds of second skin.
Old 02-12-14, 12:24 AM
  #82
Sc0pe
Sc0pe's Avatar
It's only an issue for the "Seamless" tanks since they're made a little bit differently than the standard tanks everyone's used to seeing. If you go to their "4 gallon" version, it comes right up to 3 gallons, so that's one thing to consider. I mean, the "5 gallon" version is 28" long, so running two of them... I don't know how well that will fit, but the 2x 24" ones will be a little easier. In my case, my setup will use dual Viair 480s, and dual 2.5 gallon Viair tanks (gotta keep it in the family lol).
Old 02-13-14, 12:17 AM
  #83
Shmee
Shmee's Avatar
Why do you want to use the Viair tanks/pumps?
Was bored so I spent 20 mins and threw together another model, this time with 4 of the 18" tanks....
http://www.flickr.com/photos/zx3tuning/12495713204/http://www.flickr.com/photos/zx3tuning/12495713204/ by http://www.flickr.com/people/zx3tuning/, on Flickr
http://www.flickr.com/photos/zx3tuning/12495713304/http://www.flickr.com/photos/zx3tuning/12495713304/ by http://www.flickr.com/people/zx3tuning/, on Flickr
http://www.flickr.com/photos/zx3tuning/12495353213/http://www.flickr.com/photos/zx3tuning/12495353213/ by http://www.flickr.com/people/zx3tuning/, on Flickr
Old 02-13-14, 12:49 AM
  #84
PureDrifter
BahHumBug
PureDrifter's Avatar
ohgod, the leaks
Old 02-13-14, 01:06 AM
  #85
Shmee
Shmee's Avatar
Man, I don't know why some people think it's so hard to seal up a pressurized vessel. The secret is simply NOT using Teflon tape. Some knowledge, some Loctite or Permatex thread sealant, some heat, a day to cure before pressurizing and leaks do not happen. It's really not that hard...
I have never had a leaking issue upto 600psi on any fluid or gas(not fuel) system I have designed and built, I don't know why some people struggle with 150-200psi.
Using AN fittings and high pressure Kevlar racing hose doesn't hurt either....
Old 03-27-14, 05:28 PM
  #86
Dubbayoo
Dubbayoo's Avatar
I think I'm going to look into an OEM sub. I'll pay a little more for a drop in replacement. Since I've switched to SiriusXM the sub rattling is much more noticeable.
Anyone know whether if you have the Nak OEM if there's any reason you can't use the cheaper Pioneer OEM?
Old 03-27-14, 09:22 PM
  #87
Sc0pe
Sc0pe's Avatar
So what would you recommend doing for a 200 psi system?
Old 03-27-14, 09:33 PM
  #88
Shmee
Shmee's Avatar
In what sense?
Old 03-27-14, 10:19 PM
  #89
PureDrifter
BahHumBug
Hardline all the things!
Old 03-27-14, 11:41 PM
  #90
Sc0pe
Sc0pe's Avatar
In what sense?
Basically fittings-wise. The way I have everything all "set up" is that every connection is NPT/Compression for air lines, with a few PTC fittings here, and there.
Quick Reply: LS400 Rear Deck Subwoofer Mounting
