LS400 Rear Deck Subwoofer Mounting
Old 05-16-14, 04:39 PM
  #121
ocr
ocr's Avatar
well. I decided what I'm going to do. I'm going to do the same thing Shmee did and cut out a section in the rear deck to mount an MDF board with the sub in it. few things I'll do different will be using a 10" sub instead of a 12" sub and cutting a section large enough so I can upgrade to 2 10" subs in the future.
Old 05-16-14, 05:49 PM
  #122
Shmee
Shmee's Avatar
I would suggest against the cutting a section big enough for 2 10s unless you are going to build a frame like I did and really weld it in properly. With how I did it, I could get away without doing a full coverage weld because I stayed away from the factory support braces but if you at going to cut bigger than I did you will cut through those braces and will have to do a lot of welding and make a fairly strong and structural frame for the subs.
I'd suggest cutting a single hole big enough to upgrade to a quality 12 or 15 sub rather than 2 10s...
Old 05-16-14, 06:24 PM
  #123
ocr
ocr's Avatar
I gess I could do that. I'll look at my car a bit more. My car is a UCF10, so my supports might be in a different spot. yes I am going to build a frame like you did.
Old 05-16-14, 11:11 PM
  #124
Shmee
Shmee's Avatar
I can assure you, my single 12" SPB-4, driven by a super clean 475W is more than enough sub even just using a LOC and everything turned down to pretty low levels.
I've had some big systems in the past and what I have now is beyond adaquate.
I am really happy I listened to the suggestions to go with this sub!
Old 05-17-14, 09:02 PM
  #125
ocr
ocr's Avatar
Shmee - how much did your sub cost though?
Old 05-18-14, 01:46 AM
  #126
Shmee
Shmee's Avatar
$300 + $25 S&H.
Pretty good deal considering it was hand made for me and didn't just come out of a box from an online vendor or local big box store...
Old 05-18-14, 09:50 AM
  #127
ocr
ocr's Avatar
whats its power ratings and does the company have a website I can visit to check them out?
Old 05-18-14, 10:01 AM
  #128
Shmee
Shmee's Avatar
Www.aespeakers.com
Sub is the 12" SPB 4ohm, suggested at 300W continuous and 500W max.
Old 05-18-14, 10:55 AM
  #129
ocr
ocr's Avatar
cool, thanks Shmee. ill look into them for an upgrade from my JL audio sub.
Old 05-18-14, 01:02 PM
  #130
Shmee
Shmee's Avatar
No worries man, just plan ahead and only cut once!
To build a baffle and frame like I did you'll need to add 2" to the OD of the sub to get the outside perimeter dimensions of the frame and baffle you'll need to build. If you want to upgrade to a 12" sub, you'll need about a 14.5-15" frame, for a 15" sub you'll need about a 17.5-18" frame and baffle!
12" is about as big as you can go without doing major work on the third brake light. With my cram I had to trim off a couple of tabs but it fits almost factory now, just need to trim a little off the back edge around the forward edge to sit tighter to the surround and flush to the floor again. Then it's just finding something to stuff between the deck cover and surround and fill the hold where the center seatbelt came out, to make it look a little more factory clean
Almost done... by ZX3Tuning, on Flickr
I also want to try and track down some speaker cloth similar to the factory blue-grey fabric...
Old 05-18-14, 04:41 PM
  #131
rick1987
rick1987's Avatar
Awesome work!
I would love to do this, maybe next winter.
Right now I just have a Boston Acoustics G5 12" in the trunk and I have a CT Sounds 1400 coming tomorrow.
Old 06-25-14, 04:32 PM
  #132
Sc0pe
Sc0pe's Avatar
Originally Posted by ocr
ok, I have a bit of a delima.
I have a 10" JL sub rated Rms 150w @ 4 Ohms and a 300W class D Mono Block Kicker amp rated 150w Rms @ 4 Ohms or 300W @ 2 Ohms.
My problem is I don't really want to have to cut away at the back dash. Will a 10" sub fit by just stacking a 10" MDF ring on the rear dash? If not, what other options do I have?
My only other idea to solve my problem is by just getting a 8" sub. If I do that, I'm looking at getting the Kicker CompS 8" Single-Voice-Coil Subwoofer rated 200w Rms @ 4 ohms or Kicker CompR 8" Dual-Voice-Coil Subwoofer rated 400w @ 2 ohms.
What would be my best option for dropping a new sub into the rear dash using the Kicker 300.1 Class D Mono Block amp?
Here's a thread on mounting a 10" subwoofer in the OEM 8" space.
Old 10-27-14, 07:12 PM
  #133
stopdrpnro
stopdrpnro's Avatar
Wondering if I can squeeze in a 12" without cutting. I want to just trim out the hole.sub needs an 11" cut out my idea is trim out the factory opening from 7.5" to about 10" then add 1/4" baffle on top(top reduce cutout needed) on bottom I'd add a 3/4" baffle and sandwich them togther. The rear deck is already deadened with a couple layers and I plan to seal everything with modeling clay/ rope caulk. Good idea or should I just settle for a 10" which fits with minimal trimming
Old 10-27-14, 08:52 PM
  #134
Shmee
Shmee's Avatar
Either or.
But it really depends on what you are after and how much bass you want. Doing a riser baffle is probably going to be a LOT higher than you expect and it is also going to heavily limit the flow of the airmass being moved as you neck it down like that. It is honestly not that hard to build a proper baffle and the end results are well worth it. Plus with my design, you could just build a quick little 2nd battle and throw the stock sub back in without much issue if you ever sell the car!
Old 10-28-14, 11:24 AM
  #135
stopdrpnro
stopdrpnro's Avatar
Not having the tools or the know how to weld makes it exponentially more difficult to pull off what you did. I think I'm going to be lazy and go with trim + the 10
Quick Reply: LS400 Rear Deck Subwoofer Mounting
