LS400 harness
the harness is crazy-expensive, are you sure you need to entire harness?, it's normally much more economical to repair your existing harness, the only exception would be like in the car of an engine fire.
so be more specific about your situation
The sub-harness that goes from the camshafts to the ecu is bad..i was told i have to get a whole harness...I've been searching the internet like crazy trying to find just that part of the harness
I would recommend you find a large Pick-a-part junkyard, one with a lot of LS400's and other Toyotas to find the connectors (Toyota used many connectors in common with the Lexus models) - all a harness is - is just connectors, wire, solder, and heat-shrink tubing and a little bit of practice to put it all together!
toyotasrfu
09-03-07 07:23 AM
