Check engine light on cause vsc on?
#124
The 50 degree crank angle technique is not mandatory, it is just good practice - when you rotate the engine an additional 50 degrees, you are in a much safer place as far as valves hitting pistons (sometimes a cam wants to lurch from valve-spring pressure when you remove the old belt, and 50 degrees further rotated after TDC is a place where there is minimal valve spring tension on the cams, and also some distance to the pistons if it were to "lurch")
Maybe this is why I have never needed to do the cam-tying that someone mentioned!
#125
#126
Yes this is my first time actually doing this so of course I don't want anything to go wrong and would like to go with the best route! Well I think I am going to rotate it 2 revolutions again then set at tdc just to double check before actually loosening the tensioner and pulling off the belt. Wish I can get it done and over with but work been hectic this month and have not got time to finish it lol
#130
So double check it line up at tdc and check both cams marks etc, everything turn out to be good. After checking I turn it about 50 degree clockwise and began to loosen the tensioner. Got the tensioner loose and belt is finally off
. I have already place order on new ntn tensioner and bando timing belt so those should be arriving sometime next week. I was inspecting the water pump etc and did not see any leak nor notice anything wrong with the waterpump and the idler etc. those are the only things I didn't place order on, hopefully they will last me quite some time til my next timing belt/water pump service. I can't remember, does the new bando belt come with marks?
#131
Bando, Mirsuboshi, (the two Toyota OEM's) and most every other timing belt made come with marks these days, they are really just a convenience, they don't have to be used at all, but they can be helpful - in the old days we just made our own - or sometimes we didn't!
The main thing is to ensure that the 3 sets of marks that count continue to line up on every 2nd crank revolution!
#132
#133
When installing the new belt, I will have to line up the right/left cam mark on belt to the marking on the cams itself first correct? Since it is still at 50 degree, so I would match up the mark of the new belt with the marks at 50 degree then rotate about 2 revolution and then should line up at Tdc?
#134
did you watch the video? - if so, watch it again - he shows this part pretty extensively
it's very important that you understand the theory when changing a timing belt, otherwise, engine go bye-bye
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#135
