1996 LS400 Wont start with key
Old 11-24-13, 08:04 AM
zero9
zero9's Avatar
Angry 1996 LS400 Wont start with key
When I turn the key to the on position, all the lights, the ac, the radio, everything works but nothing happens when I turn the key, no noise no click no nothing? We just had the heads resurfaced, changed the timing belt, water pump, all the pulleys etc. We bought the car to fix up for my wife to drive. All the fuses, the battery and terminals and all electrical test good. Could it be a security issue? Help please!
Old 11-24-13, 12:03 PM
RA40
Super Moderator
RA40's Avatar
Welcome on your first post.
My thought would be to check the harness to the starter. One or more of the wiring harness sounds like it is disconnected.
Old 11-24-13, 01:34 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
unlikely to be a security issue no immobilizers on '96 cars.
Old 11-24-13, 03:14 PM
dashan
dashan's Avatar
Clean the battery cable terminal connections.
Old 11-24-13, 03:53 PM
LScowboyLS
LScowboyLS's Avatar
on my '96, the positive battery terminal was bad where it bolts to the cable - make sure to get the real Toyota part (about $15 at any Toyota dealership, don't bother with the Lexus dealership on this, same part!)
Old 11-24-13, 04:46 PM
Yamae
Yamae's Avatar
Did you check the neutral safety switch?
When it fails, there's no noise, no click and nothing happens.
Old 12-24-13, 02:13 AM
zero9
zero9's Avatar
Default one split wire over transmission
ra40 gave me idea sorry it so long I unplugged the neutral safety switch thru the wires over the trans.and starting checking for an open none but I did find two with high ohm readings they high I the plastic protector and found the insalation was splitting open the wire was full of green power I cut the section out solder new in no problem since also this was not where I started thanks for all advice and help
Old 01-04-14, 01:27 AM
shanjam
shanjam's Avatar
does engine turn over? if yes put key into on position wait 6mins turn off turn on start try that good luck
Old 01-04-14, 09:12 AM
Gene01
Gene01's Avatar
Hi, shanjam. Could you let us know what the 6 minute power on cycle does?
Old 01-04-14, 04:53 PM
PureDrifter
BahHumBug
he had a '00 car, wouldn't apply to an early 2nd gen anyway.
Old 01-04-14, 07:11 PM
YoshiMan
YoshiMan's Avatar
96s very much DO have an engine imobilizer system... It is just not tied in with the key.
Have you had the alarm go off at all recently? I had an old Toyota Cressida that had an issue just like this and it was one of the little switchs inside the door on the key cylinder that had become brittle and broken off. The switch was stuck in a "half" position which confused the security computer and kept the starter from engaging even with the key in the ignition. I also had the alarm go off and random sometimes. Just throwing in my two cents if nothing else seems to work.
Old 01-05-14, 01:35 AM
LScowboyLS
LScowboyLS's Avatar
Cowboy likey this answer!
justunme
03-12-18 01:57 PM
macdaddy6
05-06-12 07:08 AM
lazybummm
07-15-09 12:02 PM
92lexus
Maintenance
12
02-13-03 07:14 AM
Quick Reply: 1996 LS400 Wont start with key
