Brake Squeak Noise and Shim Kit
Old 11-24-13 | 07:25 PM
Michael's Avatar
Michael
Default Brake Squeak Noise and Shim Kit
Last time when I did the front brake job, I removed all of 3 anti squeal shims because they were so rusty. I have applied some brake grease on the back of the pads. They were OK but had little bit of problem with a squeal noise only in summer time and I was able to live with that. I am debating weather to buy the kit and put them on for the next brake job this time around. Another extra $30 or so for the brake job. I did the same thing for the rear and no problem there. Any opinion on weather I should use the kit or not? Anyone had success without using the kit or using old rusty ones? Is there a workaround?
Old 11-24-13 | 07:51 PM
LScowboyLS's Avatar
LScowboyLS
if you want your car to be classy and quiet like an LS400 should be, buy the real factory shims at the dealership - use an online dealership like Sewell or Lexus of South Atlanta or Park Place or Lexus Parts Now to get a 25% or more discount! - also check ebay for the real Toyota shims new in a box that someone ended up not installing because they sold the car.
Old 11-25-13 | 02:10 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
i believe centric sells the shims as well as a "brake fitting kit" but i may be mistaken.
spacecoupe
Suspension and Brakes
12-30-13 02:24 PM
DMPesso
08-16-13 02:39 AM
I8ABMR
04-27-12 10:18 AM
seivonecsu
04-12-12 05:13 PM
denvergs4
10-26-07 08:37 PM
Quick Reply: Brake Squeak Noise and Shim Kit
