LS Almost Stalls When Coming to a Stop?
Old 01-04-14, 11:46 AM
AtlasLS400
AtlasLS400's Avatar
finally got some time to work on the car today. Drained the fluid, dropped the pan, replaced the filter. I also checked for any loose wires and tested the ohms on the solenoids. All were around 10.5 and 11.5 ohms. (Battery was disconnected). I also bent the connectors a little to make sure there was a good contact. Some of the guys on the GS forums were having some luck with that. Fluid was bad and filter was definitely due for a change. There was NO debris at all on the magnets.
Once back together and testing results, my harsh engagements into reverse or drive from park were no longer happening. Jerking into gear on up shifts were no more. BUT STILL... When coming to a stop car wants to shutter on the last 20mph. It's like it doesn't want to come out of 4th or 3rd. There are no codes, (for now) but I'm sure it will pop back up after driving around some more. I'm probably have a full diagnostic done on the trans. Perhaps get the caps done.
Any thoughts? I've been reading all over the forums. Most stories end at the drain and filter change.
Old 01-04-14, 12:18 PM
AtlasLS400
AtlasLS400's Avatar
Also forgot to mention that i am able to manually downshift through the gears just fine. It's only when i keep it in drive it wants to shutter to a stop.
Old 01-05-14, 02:07 AM
LScowboyLS
LScowboyLS's Avatar
97 LS400 with 200k just do not tend to have transmission issues, at all (at least not any that a fluid and filter change won't cure!)
being in Florida and being a 97, this sounds like a textbook case of failing ECU capacitors
Old 01-05-14, 10:21 AM
AndyTTT
AndyTTT's Avatar
What's the significance of the car being from Florida - heat, humidity or both? Coming from the north of England not problems I am familiar with! [I knew I'd find a benefit of living in a cold climate if I waited long enough]. Seriously though, are cars from a cool climate less likely to suffer from capacitor problems?
Old 01-06-14, 04:25 AM
LScowboyLS
LScowboyLS's Avatar
we don't fully understand it, but hot and humid Florida has ECU capacitor issues reported at a higher rate than any other place, although locations around the world are affected, just not at such an extremely high rate.
Old 01-06-14, 04:32 AM
AtlasLS400
AtlasLS400's Avatar
Stupid Florida
Old 01-06-14, 06:17 AM
LScowboyLS
LScowboyLS's Avatar
also cars that have sat for extended periods, this is also very hard on ECU caps, capacitors are like tiny batteries, and we know that batteries that sit for a long time without being used tend to go bad fast. - This is why any ECU from a junkyard or ebay should have its caps replaced ASAP.
Old 01-11-14, 07:31 PM
AtlasLS400
AtlasLS400's Avatar
UPDATE.... I had the caps redone on my ecu. Still.... The shuttering remains. On a better note, acceleration feels better. Don't know what to do about this now. I've done everything I could do myself. Any suggestions?
Old 01-11-14, 09:40 PM
LScowboyLS
LScowboyLS's Avatar
have you replaced the transmission mount? (easy and cheap)
Old 01-12-14, 06:38 AM
AtlasLS400
AtlasLS400's Avatar
I had the mount done a year ago. Could there be something going on with the rear end to cause the shuttering and clunking that I'm getting?
Old 01-12-14, 07:36 AM
LScowboyLS
LScowboyLS's Avatar
have you done caps, rotors, wires, plugs, and cleaned throttle body?
Old 01-12-14, 07:55 AM
dc893
dc893's Avatar
You pulled the code that said it was a faulty solenoid, didn't you?
Old 01-12-14, 08:14 AM
LScowboyLS
LScowboyLS's Avatar
yeah, and then he tested them, and as I predicted, they were fine
Old 01-12-14, 01:56 PM
AtlasLS400
AtlasLS400's Avatar
Ok so with the work already performed, I am beginning to lean towards a torque converter issue. Did some research and the symptoms are very similar. I know these TCS don't normally have problems but I'm kind of forced to consider it
Old 01-12-14, 05:54 PM
usoff89
usoff89's Avatar
If that ends up being your issue. I still have my old trans and convertor.
Quick Reply: LS Almost Stalls When Coming to a Stop?
