Recently acquired LS400 ~ some questions
Well the car is with the dealer and the p/s leak is being attended to. Fingers crossed all goes well. I put over 100ml in the reservoir the other day. It's some leak, the cardboard I put under the car turned red in 4 or 5 places. (it's a little worrying ... that it appears to be more than one leak although they are in one general area) Hopefully there won't be any alternator issues at any time.
Had a bit of trouble with the steering reach. It stopped working but was okay at the dealers. When I pulled the lever towards me I heard a faint squeak then nothing, no movement, when I pushed the lever away I heard something like a motor turning for half a second, then nothing, no movement.
Today I did as a few here have suggested, push the lever 10 times. It works. I wonder if the tilt motor can be serviced before it fails. Maybe a bit of appropriate lubricant on the threads? Because now the wheel tilts and recedes all the way away from the seat when I remove the key.
Just today I noticed a couple of times moving off from standstill and giving the engine a good bit of juice. There's a bit of a noise from behind me somewhere, outside, a good chance under the car. Sounds ominous but without further checking I don't yet know what it could be. It does not make the noise when I feed in the juice when not stationary.
My workshop repair manuals are in the FedEx facility across town so they'll be here any day.
One more manual I want to get, the diff overhaul repair supplement. Are the LS400 diffs all the same from 1989 to 2000? I just want to be sure I get the right book.
Thanks again in advance.
I've just gotten hold of a CD magazine for the car. What's the idea behind the 2 stickers which I'm supposed to affix to the outside of the magazine?
Thanks in advance.
Thanks in advance.
failing ECU capacitors can cause this, or a clogged filter - be very careful who does the filter change on your transmission as this involves pulling the pan and this job can be botched by the incompetent. - Use the genuine Toyota filter!
As far as transmission oil I was reading that Toyota Type T-IV had a different viscosity rating than Mobil 3309. Does Toyota's fluid have some additional additives that would make it 'better' than Mobil 3309 or other manufacture approved JWS 3309?
Thanks to YoshiMan I was able to locate the correct part #
I'm not sure MM/YYYY when Lexus changed the CD stacker, but if you need an early one, this is it.
Presuming you have an eBay account to view:
http://www.ebay.com/itm/LEXUS-LS400-...-/261381140300
I don't know the part number.
This is the later one:
http://www.ebay.com/itm/NEW-LEXUS-RX...-/171228558072
On the earlier stacker you can only swing out one tray at a time. On the later one you push a release button and they'll all slide out at once if you want that.
Just to confirm the part number that you found for the 98 Lexus Stacker, on the Toyota box the stacker came in it's 86273-50050. Even though it's a Toyota box, the stacker has Lexus printed on it.
I'm positive that someone will be along with the part number you're after.
I looked there but was not able to locate it within the list provided. (I am not sure what section it would be under and how it would be titled but I searched for a good 40 minutes for the CD Changer and various other parts. Thanks for the tip!
Hi all, got the key from the dealer and now I can lock and unlock the car remotely. I tested the alarm and that's fine however I can't open the boot when I push the button on the key. The LED on the key lights up when I push the button to open the boot though. Where should I start looking to see what the problem is?
I'm after recommendations for front brake pads too. I'm not at all hard on the brakes yet the front wheels have pad a lot of fallout on them after 600 Km, most of that rural. No idea what sorts of pads are currently fitted. Hopefully there's a 'magic' pad set out there which pull the car up well without dirtying the wheels too much.
Thanks in advance..
Thanks in advance..
I am fairly new, while browsing ******* parts catalog for my VIN I am confused as to what part is which. My car is 1996 LEXUS LS400 (UCF20L-AEPGKA) USA 1UZFE 4FC. I was curious which part code is for the transmission filter, and since I am considering replacing the filter would you recommend replacing the gasket, bolt, etc
● drain bolt is part number 90341-10011
● gasket is part number 35178-30010
● filter is part number 35330-50010
they also make some other JWS 3309 on the same production line, such as Volvo, Saab, Mazda and a couple of other JWS 3309 brands
I have actually been able to negotiate the best deals on T-IV, so I use that, but if I could find one of the other brand bottles cheaper, I would use it!
Hi BeLSNow111 here at home I have an old CD player model number PD-502M and the stacker in it says 'for car and home use'. The stacker is identical to those fitted to early Lexus vehicles.
Please see: http://www.ebay.com.au/itm/Pioneer-6...3D251389182987
Vendor states that it is in very good order.
If you're still looking for a stacker, it's the only one I could find and as I type this there are 32 hours to go. Whether the vendor will ship to the states is another thing,
BeLSNow111, please see:
http://s354.photobucket.com/user/kev...g.html?filters[user]=139223608&filters[recent]=1&sort=1&o=1
and
http://s354.photobucket.com/user/kev...g.html?filters[user]=139223608&filters[recent]=1&sort=1&o=0
(Photobucket pics don't load here?)
I asked the vendor, whom I have absolutely no affiliation with, about shipping to the USA and he replied he wants to know an exact postcode.
cheers
and
cheers
One of the bulbs in the left hand headlight assembly isn't working so I need to take a look. Presumably, I have to remove the assembly to get to the bulb sockets, otherwise I'd need to remove the battery, at least. I can see 2 bolts and a screw holding the assembly in place. Is there anything else I need to be aware of before removing the assembly? Such as headlight levelling mechanisms etc. Just to remind, the car is right hand drive.
Also, under where the right hand bonnet strut mounts there is a small horn of sorts. What's it for? I thought it was the chirper for remote locking but the chirp seems to come from the left side of the engine bay,
Thanks in advance.
edit: The car has HID lamps if that makes any difference.
(This link is for my info so I can find the thread again, easily).
https://www.clublexus.com/forums/gs-...elt-cover.html
Thanks in advance.
