2000 LS400 problem with steering wheel adjust
Old 12-29-13, 09:03 AM
tcordi
tcordi's Avatar
Default 2000 LS400 problem with steering wheel adjust
We recently had our LS400 detailed and when we got it back the steering wheel was stuck in a low position. It will telescope in and out but won't go up or down It makes a "whistle" sound when you push up and no sound when you push down.
I tried a search and saw one post that stated a fix for this feature can run $2K Hopefully someone knows any easy fix. New to forum and thanks in advance for any advice on solving this issue.
Old 12-29-13, 06:36 PM
Kansas
Kansas's Avatar
Look at the "sticky" at the top of this LS400 forum for a link to the thread on fixing this issue - at least the fix works some of the time.
Old 12-29-13, 08:14 PM
rick1987
rick1987's Avatar
I thought the 2000 was different?
Old 12-29-13, 09:09 PM
tcordi
tcordi's Avatar
Hmmmmm! Thanks Kansas. Like your avatar. Keep them mower blades sharp...
Old 12-30-13, 03:53 AM
Kansas
Kansas's Avatar
Yes, 2000 LS400's made later in the model year had revised tilt and telescope motors. I do not know if adding washers behind a sprocket or reversing a sprocket will work to fix the problem like it did on earlier LS400's.
My 2000 was built in June 2000 so I was lucky to get the revised parts installed at the factory ... haven't had any problems ... yet.
Here again is that TSIB dated May 19, 2000..
Yep, keepin' 'em real sharp ... never know when I'm going to need one of them blades ... uh huh ...
Old 12-30-13, 06:53 AM
billydpowe
billydpowe's Avatar
yes the 98 and up are very different and the old way is gone forever......
I had to replace the motor, 500$ including labor(200).. I didnt have the guts to try.
Attached Thumbnails 2000 LS400 problem with steering wheel adjust-100_2316.jpg   2000 LS400 problem with steering wheel adjust-100_2317.jpg   2000 LS400 problem with steering wheel adjust-430-2.jpg   2000 LS400 problem with steering wheel adjust-430-3.jpg   2000 LS400 problem with steering wheel adjust-430-1.jpg
Old 12-30-13, 06:19 PM
rick1987
rick1987's Avatar
Ouch! I wish someone could figure this out.
My tilt is starting to make noise. $500! Wow
Old 12-31-13, 07:40 AM
YoshiMan
YoshiMan's Avatar
What about small electric motor rebuilding services? I bet they could put new brushes in those without much fuss. These little motors aren't too terribly scary once you open them up.... unlesss of course everything looks okay, then i guess it's time to replace!
Old 12-31-13, 08:36 AM
fixmiester
fixmiester's Avatar
The newer style motors do not have brushes; they are electronically commutated and are totally controlled by the electronics.
Old 12-31-13, 08:47 AM
billydpowe
billydpowe's Avatar
YoshiMan, there are no brushes in the new ones, they are magnet contacts (?) I took it apart but could not make it work....
Old 01-01-14, 01:42 AM
Odzsee
Odzsee's Avatar
Hi,
I have the same problem my 1999 Ls.Not tilt and telescopic steering column.First only noisy the two motor,after little time broken both motor.
My friend electro genius.He dismantled motor house and he astonished.Magnetic motor: Egads: Correct name: permanent magnet stepper motor.Not included normal electric motor copper roll.Only magnet and porcelain internal.Not associated parts from web.Therefore not repairable.Just replace complete two motor : Cry:
The same problem Land Cruiser 100.Motor is very expensive.I not change.
If know solution this problem(ebay or etc...) please report.
Pictures my tilt motor.
Thanks.
Attached Thumbnails 2000 LS400 problem with steering wheel adjust-dsc_0140.jpg   2000 LS400 problem with steering wheel adjust-dsc_0141.jpg   2000 LS400 problem with steering wheel adjust-dsc_0142.jpg
Old 01-01-14, 08:19 AM
dengman
dengman's Avatar
my as pictured tilt motor is dead. I took it out slammed it on the ground 5 times and put it back in and it worked for about a week. Then stopped again.
Old 01-01-14, 08:30 AM
billydpowe
billydpowe's Avatar
I had mine put in, couldn't figure it out, how did you do it? will my photos help?
Old 01-01-14, 01:57 PM
rick1987
rick1987's Avatar
Is there anything we can do to help stop these motors from failing?
And what kind of grease do they put on the shaft? It looks like mine could use some lube.
Old 01-01-14, 06:57 PM
JBrady
JBrady's Avatar
Mine failed with the column in the UP position.
Used vise grips to turn it and lower the column until it was where I like to drive it and haven't thought about it since.
Sux that these fail. I believe the programming to completely raise and then lower the wheel at every key insert wears the tilt motor unnecessarily.
Oh well.
Quick Reply: 2000 LS400 problem with steering wheel adjust
