Code 13, and yes I have searched the forums. THIS MAKES NO SENSE!!!
Old 01-07-14, 07:50 AM
  #61
dreamer1q
dreamer1q's Avatar
All plug wire routing is based on the diagram that Cowboy has posted above. Checked and rechecked as per the diagram. 2, 8, 3 and 5 on the top coil, and 1, 7, 4 and 6 on the left lower coil.
Old 01-07-14, 07:55 AM
  #62
python
python's Avatar
no need for the attitude..wet can be oil as well. did u have the ignitor checked? coil ohm'ed out?
Old 01-07-14, 08:08 AM
  #63
dreamer1q
dreamer1q's Avatar
Sorry, but I take offense when someone asks for a photo of a plug to define wet. Like I said, not a professional, but not a first time stooge either. I know cars, very well, so I guess I take it personally when someone questions my definition of wet. Sorry.
All of these have been covered in the previous posts as well.
All coils have been checked and rechecked, all wiring has been checked, ignitors have been bypassed and fired, ecu has been bypassed and replaced.
Old 01-07-14, 08:26 AM
  #64
Finn
Finn's Avatar
I'm sorry to be this **** - feel free to punch virtually - and I believe it's still just a typo in your post but plug lead order on the driver's side cap is not 1-7-4-6 but 1-7-6-4.
Old 01-07-14, 08:34 AM
  #65
python
python's Avatar
http://www.justanswer.com/lexus/1i2w...-trac-off.html
Old 01-07-14, 08:45 AM
  #66
dreamer1q
dreamer1q's Avatar
Yes, I was just giving the cyl numbers, not the actual order Finn
Old 01-07-14, 08:47 AM
  #67
dreamer1q
dreamer1q's Avatar
Both Cam sensors were replaced, wiring is fine on them. Resistence is correct at the harness and the cam sensor plug.
Old 01-07-14, 09:06 AM
  #68
LScowboyLS
LScowboyLS's Avatar
again, if cams sensors or their wiring were the issue, the plugs fired by both coils would be involved, not just one coil, same with jumped time
Old 01-07-14, 01:56 PM
  #69
python
python's Avatar
He most likely has more than 1 issue going on
Old 01-07-14, 02:42 PM
  #70
LANcr3w
LANcr3w's Avatar
i have a 94 ls400 as well, i had a code 13 for a while and couldnt figure out what it was. I thought it was
a ECU issue so i had that fixed and it still appeared. My car ran like complete crap though.
I checked timing multiple times, checked for power, replaced everything that had to do with spark.
I ending up finding the wire to a Cam Position Sensor was pinched between the plastic cam cover and
the block where theres supposed to be a piece of rubber. It also didnt help that the sensor went out as
well. I see you said u already checked the wiring but probably wouldnt hurt to double check and Ohm
out the sensor and check the wiring for any flaws once again. Good Luck!
Old 01-07-14, 06:51 PM
  #71
LScowboyLS
LScowboyLS's Avatar
the most common cause of all of code 13, is jumped time by just a single tooth on just one cam, but that doesn't match the pattern of wet vs. dry plugs following the coil, that you mentioned
Old 01-10-14, 07:33 AM
  #72
stephen18
stephen18's Avatar
Any updates?
Old 01-18-14, 04:04 PM
  #73
stephen18
stephen18's Avatar
Any news..?
Old 01-20-14, 12:38 PM
  #74
dreamer1q
dreamer1q's Avatar
Timing was off, something fell down into the timing belt and made it jump time
For all those seeking help, Cowboy is a stand up guy. He knows his stuff.
Some others here are less than informed and nearly ignorant at times.....so for future reference, listen to Cowboy.
Old 01-20-14, 01:19 PM
  #75
python
python's Avatar
This wont cause all 4 of ur plugs to be "wet"...and for ur information i had to set him straight on code 13 a few months back.
Quick Reply: Code 13, and yes I have searched the forums. THIS MAKES NO SENSE!!!
