1997 LS400 170K miles, Coolant Leaks, alternator not charging, ...
Old 02-14-14, 02:22 PM
ychen
ychen's Avatar
Thanks. I am positive it's coolant and on both sides. I just need to determine where the coolant comes from.
Old 02-23-14, 03:53 PM
ychen
ychen's Avatar
All the timing covers are off now. It seems the coolant is coming along the ridgeline of the water pump on both sides. Any chance that the coolant leaks come from source other than the water pump (including gasket)?
My current plan is replace timing belt (it has cracks) & WP and all other moving parts. I ordered AISIN TKT-030 from amazon. I was examining the timing belt and found one of the nylon thread was cut on one end of the timing belt (pls see the picture). Is this going to compromise the function and longevity g the timing belt. Should I exchange with amazon? Thanks again for your help.
Attached Thumbnails 1997 LS400 170K miles, Coolant Leaks, alternator not charging, ...-img_8389.jpg
Old 02-23-14, 04:36 PM
ychen
ychen's Avatar
I failed to mention that the coolant has been leaking since I bought it (12/31/2013) even though the car has not been started since early January. Thanks.
Old 02-23-14, 04:59 PM
dashan
dashan's Avatar
You may also want to replace the fan bracket while you are there.
Amazon.com: Aisin FBT-001 Fan Pulley Bracket: Automotive Amazon.com: Aisin FBT-001 Fan Pulley Bracket: Automotive
Old 03-22-14, 01:43 PM
ychen
ychen's Avatar
Finally I finished removing everything in the front of the engine. it seems the coolant leak was from the water pump. However, I think I have much more serious issue now. The engine cylinder headers at the front (the two red arrows) have been corroded due to the coolant leak and the headers are leaking (Please see the pictures) oil I presume. What are my options now? Do I need new cylinder headers? Thanks in advance.
Attached Thumbnails 1997 LS400 170K miles, Coolant Leaks, alternator not charging, ...-img_8505.jpg   1997 LS400 170K miles, Coolant Leaks, alternator not charging, ...-img_8507.jpg   1997 LS400 170K miles, Coolant Leaks, alternator not charging, ...-img_8506_2.jpg
Old 03-22-14, 01:50 PM
LScowboyLS
LScowboyLS's Avatar
I cannot see your photos very well on this phone (not at home) - but those look like freeze out plugs
why are you calling them headers?
headers are a tuned exhaust manifold of equal length pipes for each cylinder, and your LS400 doesn't have them from the factory
Old 03-22-14, 02:04 PM
ychen
ychen's Avatar
Sorry for my ignorance. Can I just replace them?
Old 03-22-14, 02:09 PM
LScowboyLS
LScowboyLS's Avatar
can't see well enough to tell you what the arrows point to for sure, but if they are indeed freeze plugs, yes you can replace them and they are not expensive, but they will have to come from the dealership to insure proper fit (online dealership like Sewell Lexus, Lexus of South Atlanta parts, Park Place Lexus, or Lexus Parts Now are all fine)
Old 03-22-14, 02:45 PM
ychen
ychen's Avatar
Thanks to Cowboy for your prompt response. The two arrows point to the corroded parts inside the two discs. I could not find any thread on how to replace them. Is it a hard task? Thanks again.
Old 03-22-14, 02:58 PM
LScowboyLS
LScowboyLS's Avatar
it is easy to replace the freeze plugs - Toyota calls them "PLUG, TIGHT, NO.1" - the part number is 96411-43000 - the cost is $3.83 each at Sewell Lexus
I would replace at least both of the freeze plugs on the front side of the each head, and I would take a mirror and a strong light and take a good look at the identical 2 plugs on the back side of each head, and replace those as well if they are leaking or corroded, all 8 freeze plugs in the heads are the same part number.
the cause of this is usually due to people not changing their coolant using Toyota long life red and distilled water every 3 or 4 years!
the ones on the back of the head may be too hard to get to, with the heads in the car, I am afraid, so hopefully those will look OK, or else this has become a big job!
Old 03-22-14, 03:04 PM
LScowboyLS
LScowboyLS's Avatar
here is a video how-to
Old 03-22-14, 04:19 PM
ychen
ychen's Avatar
Thanks again Cowboy!.
Old 03-22-14, 06:39 PM
LScowboyLS
LScowboyLS's Avatar
to get the tool he used (a little bit expensive) - you can see if any auto parts stores will loan it to you, otherwise, I can help you find it on ebay, then you use it, then put it back on ebay, sell it, and get your money back!
Old 03-22-14, 07:10 PM
LScowboyLS
LScowboyLS's Avatar
here are some of those Mac Tools freeze (expansion) plug installation tools on ebay for around $50-$75
Old 03-23-14, 12:53 AM
ychen
ychen's Avatar
Thanks for the link on ebay. I have watched some videos on Youtube. It seems pretty straight forward. I will replace the 4 on the front for sure. The ones on the back are really hard to see let alone replacing them.
Quick Reply: 1997 LS400 170K miles, Coolant Leaks, alternator not charging, ...
