Best aftermarket radiator for 97 LS 400
well the genuine Toyota radiator, of course! - but once you see the price, you might want to opt for a Ready-Rad from Advance Auto Parts - they are decent
if your car has less than 250-300K miles, the problem is likely not the radiator, especially if the Toyota red coolant was used mostly throughout the car's life - as the stock original radiators rarely fail.
koyo
ready rad..proliance and many others are mostly Chinese made with different names on them. and radiators do fail..mine did, u have no idea what type of maintenance has been done, people read on the side of the coolant bottles that the coolant is good for 50,000 miles or longer,this simply isn't true. coolant should be changed every
2-3 years and no longer than 30,000 miles to prevent corrosion. you own a diesel engine? toss this in to prevent cavitation
http://www.napaonline.com/Catalog/Ca...056_0429168677
Even if the Nissens (Danish company, IIRC) is most expensive of the list it's not that bad. I have been quite happy with Nissens in the past - at least my -89 MR2 received a Nissens radiator.
Lexicon1
Maintenance
11-13-06 09:34 AM
