92 LS400 Replacing front Low Beam Bulb
Old 01-31-03, 02:47 AM
dbullen
dbullen's Avatar
Default 92 LS400 Replacing front Low Beam Bulb
Last time I had to replace a front bulb I had it done at the dealership. I now have to replace another one and I can not figure out for the life of me how to do it! Does anyone have instructions on how to replace the low beam bulb for 90-92 LS400's?
Old 01-31-03, 05:31 AM
tn52
tn52's Avatar
Default Low beam replacement?
I have a 93 but I hope earlier model should be the same. On mine, the bulb is for both low AND high. The procedure is a little different for each side.
Driver side: remove the battery to gain access
Passenger side: remove the air filter housing
After you remove these things, you should be able to see the back connection of the bulbs. Remove the connections (squeeze on the clips then pull back, remove the rubber cover, undo the holding spring clip then the bulb will come out. Be carefull NOT to touch your new bulbs AND replace them in PAIR! It a good time now to upgrade.
Old 01-31-03, 10:07 AM
kjbro
kjbro's Avatar
Default Headlight Replacement
dbullen, I also replaced a drivers side headlight bulb within the past 6 months and placed a post on this subject. I hope the attached string works for you. I learned a few things that might help you. If the thread does not work, look for posts from kjbro and find headlight topics. Became an easy project, once I completed the job. My car is a 95 LS400. Good luck
https://www.clublexus.com/forums/sho...threadid=60382
YODAONE
05-30-19 08:03 PM
rkorduba
ES - 5th Gen (2007-2012)
01-13-17 06:59 AM
brybo86
11-23-15 03:00 PM
ibgolfn
GX - 1st Gen (2003-2009)
10-24-12 06:35 PM
gbcoe
11-15-07 08:09 AM
Quick Reply: 92 LS400 Replacing front Low Beam Bulb
