2000 ls400..strange pcv valve.
Old 01-23-14, 08:41 PM
Greg5OH
Greg5OH's Avatar
Default 2000 ls400..strange pcv valve.
I wanted to change my pcv valve today.
I ordered the all metal ones, which i now found out are for 90-97. I need the 98-00 which is plastic and has a 90 deg elbow on it.
Question, how do i remove it though? i tried twisting the collar and pulling, it didnt move.
Old 01-23-14, 08:46 PM
SynicalVip
SynicalVip's Avatar
If I remember correctly all you got to do is pull it out. It may take a little more pull to get it out. Hope you order the grommet piece as well. When changing the grommet, it may break into pieces, as it gets brittle over time. Try not to drop any broken pieces in
Old 01-23-14, 08:50 PM
Finn
Finn's Avatar
On a -91 the valve comes out just by grabbing it with a suitable tool and pulling out. On my LS the old grommet was hard and to take it out easier we cut it at one point. Then it was easy to turn the end of grommet "in" and pull it out. Old hard grommet breaks quite easily.
Old 01-23-14, 09:17 PM
LScowboyLS
LScowboyLS's Avatar
I think I would treat it with something to soften the hard grommet a day or two in advance of trying to remove it - if you drop bits of the broken grommet into the the valve train ....... well, I don't have to tell you how that is gonna turn out! - lol
Old 01-23-14, 09:25 PM
dc893
dc893's Avatar
The pieces cannot fall into the valve train. It is blocked from letting those pieces being able to fall inside but I wouldn't wanna leave them in there.
Old 01-23-14, 09:39 PM
LScowboyLS
LScowboyLS's Avatar
maybe not directly fall in, but small pieces could get down there eventually, the crankcase gases get through, so it ain't sealed!
Old 01-24-14, 03:13 PM
YoshiMan
YoshiMan's Avatar
Having large hardened plastic-like rubber pieces floating around near the spinning camshafts isn't really a happy thing either!
mekelly
03-30-24 06:08 PM
trhs75
RX - 1st Gen (1999-2003)
05-17-13 09:07 PM
Bradlex
04-23-12 10:24 AM
C-Stone
12-17-11 06:09 PM
jbobst
08-21-11 11:49 AM
Quick Reply: 2000 ls400..strange pcv valve.
