I just purchased a 1996 LS400 with 218XXX Miles. Maintenance Advice? I have a list!
I have read that article in the past. I just gave it anoter read thru and although I understand a benefit from using 0W-30 I will probably stick with 5W-30 synthetic and let my car warm up for a couple minutes. I am switching my oil filter to the Motorcraft FL400S, that should help with start-up wear.
(Sorry for all the pettyish questions! I am completely new to fixing my car myself. Even though I i need to save $$ I definitely do not want to sell myself short) I appreciate any help provided!
I may be the similar post. I recently got a 1997 las with 111,111 miles. These guys on here are spot on with their maint advise. Mine is dialed in really well now. What did you pay for that beauty?
You definitely are the similar post. If you click the quotation from Cowboy it links to your thread.
With fees and registration $3000 out the door. Best of 6 others I test drove in the area.
Thanks midwest for clarifying on the fan.
Is Item 12371 the Transmission Mount you speak of Cowboy?
http://lexus.sewellparts.com/oem-cat...S400-1996.html
EDIT: Saw your post in another forum. Looks like I found the right part# Thank you sir!
Tie Rod Ends? Inner AND Outer?
I have located these two parts #'s They both state that they are inner, and judging from the diagrams I cannot distinguish much of a difference
45503-39095
45504-59025
45503-39095
45504-59025
I might know of a deal on the driver's side one
I would be sure the valve cover gaskets are even leaking, and even if they are, it would have to be enough of a leak to be consistently hitting the exhaust manifold and making a bad smell (after cleaning the area with engine cleaner) to make that repair a good value in time or money.
