Ls400 overheats when idle
Old 02-07-14, 03:14 PM
  #31
LScowboyLS
LScowboyLS's Avatar
no, that is a cheap torque wrench, definitely NOT want you want to use!
Old 02-07-14, 03:19 PM
  #32
LScowboyLS
LScowboyLS's Avatar
home depot's is not long enough, you need to get this one from Lowe's
Old 02-07-14, 03:20 PM
  #33
Comptia
Comptia's Avatar
http://imgur.com/lB1sd5XI found my breaker bar, and i have a 17mm socket that fits the bolt
Old 02-07-14, 03:28 PM
  #34
LScowboyLS
LScowboyLS's Avatar
the six point socket is either this one or this one - not sure, not near my car at the moment
Old 02-07-14, 03:29 PM
  #35
LScowboyLS
LScowboyLS's Avatar
is the socket a six point?
Old 02-07-14, 03:30 PM
  #36
LScowboyLS
LScowboyLS's Avatar
that set up that you have in the pic should do the trick, if the bolt is not buggered up (rounded off)
Old 02-07-14, 03:32 PM
  #37
pacmonkey
pacmonkey's Avatar
How about the thermostat? Did you replace that as well when you bled it?
Old 02-07-14, 03:34 PM
  #38
Comptia
Comptia's Avatar
I just got the bolt off, put in some coolant to the top, turned car on and ran the heater. It started bubbling like crazy getting coolant everywhere
Old 02-07-14, 03:49 PM
  #39
Comptia
Comptia's Avatar
Well i ran out of coolant, it literally shot out like old faithful when i turned the car off. http://imgur.com/MaTk9jL It still isnt full from the bolt hole so im going to buy some more coolant from the store.
Old 02-07-14, 03:59 PM
  #40
LScowboyLS
LScowboyLS's Avatar
unless he has the real Kuzeh thermostat from the dealership on hand, he would likely be doing himself a downgrade by replacing it
Old 02-07-14, 04:00 PM
  #41
LScowboyLS
LScowboyLS's Avatar
make sure to use distilled water for the 50/50 mix if you want your radiator and heater core and water pump to last a long time!
Old 02-07-14, 04:09 PM
  #42
Comptia
Comptia's Avatar
Do i keep adding coolant until it stops going going down/bubbling?
Old 02-07-14, 04:53 PM
  #43
cobalt91
cobalt91's Avatar
Let the car cool off. Then add coolant. Squeeze the hose to burp out air. Reinstall fill bolt. Now fill the over flow tank to the cold line. Watch the tank over the next couple of drive cycles. Only fill the tank when its cold.
Old 02-07-14, 05:31 PM
  #44
LScowboyLS
LScowboyLS's Avatar
this is where that new Toyota radiator cap will pay off - the whole magic of LS400 self-bleeding depends on a very good condition or new cap!
Old 02-07-14, 09:16 PM
  #45
Comptia
Comptia's Avatar
Thanks for the help guys. Is this the fan fuse you are talking about, the pink one?
http://imgur.com/moLqIs1
Quick Reply: Ls400 overheats when idle
