Ls400 overheats when idle
Old 02-04-14, 09:35 PM
Comptia
Comptia's Avatar
Default Ls400 overheats when idle
I recently bought a 97 ls400 and discovered it overheats when im not moving. Also the heater blows cold air when im not moving. I haven't checked to see if the radiator fan was turning on yet. Any ideas what the problem could be?
Old 02-04-14, 10:11 PM
black_LS
black_LS's Avatar
Check the coolant level.
It sounds like there's air in the system, try bleeding it.
Old 02-04-14, 10:27 PM
Comptia
Comptia's Avatar
Will try this. Thanks
Old 02-04-14, 11:51 PM
LScowboyLS
LScowboyLS's Avatar
check the fins of the condenser (the part you think of as the radiator, when viewed from the front) for bugs, dirt, plastic bags, or bent fins
when checking the coolant level, check not only the overflow (plastic) tank, but also check at the fill bolt, a large downward pointing bolt behind the thermostat housing - you will need a wrench or ratchet/socket to check this, and it should be full.
check that the electric fan is coming on, if the electric fan is not on during this overheating (and it should be on anytime the car is getting hot or the A/C is on), then a common culprit is the temperature sensor in the bottom corner of the radiator, down below the battery
also, the car can overheat for several other reasons, such as a worn fan clutch, clogged radiator, or even a worn out radiator cap
Old 02-05-14, 12:13 PM
Comptia
Comptia's Avatar
The electric fan is not turning on when the car gets hot or ac is on. Should i replace the temperature sensor? Is it something i can do myself?
Old 02-05-14, 01:33 PM
LScowboyLS
LScowboyLS's Avatar
yes!
I don't know your level of mechanical competence, but you can always find a friend with good mechanics skills to help you, here is what I would do:
first, (optional) I would verify that the fan motor itself is good, using a heavy jumper with alligator clips, apply +12V power from battery to blue wire on connector at fan motor and connect black wire on connector to battery negative and verify that motor spins up
then check 30A RDI FAN fuse for continuity
finally, replace coolant temperature switch in bottom corner (driver's side) of radiator with a new one, aftermarket from auto parts store is OK on this part. The aftermarket part should be an exact replacement for Toyota part number 89428-33010 which Toyota calls "Temperature Detect Switch No. 2"
Old 02-05-14, 06:48 PM
MattLS400
MattLS400's Avatar
Originally Posted by LScowboyLS
yes!
My 96 also has this temp detect switch....With reference to my half temp issue mother thread, do you think it wise for me to change this temp switch ?
Old 02-05-14, 07:24 PM
Yamae
Yamae's Avatar
I often find guys who run without confirming what are ahead and behind of them.
Old 02-05-14, 07:52 PM
LScowboyLS
LScowboyLS's Avatar
only if the fan is failing to run when temp goes to half or A/C is on, it should be running in those two situations
Old 02-05-14, 08:12 PM
Comptia
Comptia's Avatar
I bought the temp sensor from autozone, plan on putting in tomorrow. I might as well replace the other temp sensor while im at it, can i use the same one from autozone or should i get an OEM one?
Old 02-05-14, 09:07 PM
LScowboyLS
LScowboyLS's Avatar
the main one for the ECU is a green one with two wires that sits behind the coil and should be OEM, there is a guy on ebay selling them for $41 shipped, cheapest price I have seen for the real Toyota part
Attachment 498617
Old 02-06-14, 04:09 PM
Comptia
Comptia's Avatar
Trying to remove the connector, do i just pull it straight out?http://imgur.com/G4yoZ5e
Edit:nvm i got it
Old 02-06-14, 04:20 PM
MattLS400
MattLS400's Avatar
Thats weird...Ive never noticed a one wire sensor for the gauge on my 96 :/
Old 02-06-14, 05:43 PM
Comptia
Comptia's Avatar
Well i just took the old temperature sensor out (the one on the radiator) and the new one doesnt fit. Heres a pic
http://imgur.com/VpN05om
Im about to head to the store to see if they have the right one
Old 02-06-14, 07:01 PM
LScowboyLS
LScowboyLS's Avatar
this is why I gave you the original Toyota part number, so the idiots at the parts store might have some remote chance of giving you the correct one!
Quick Reply: Ls400 overheats when idle
