Supra upgrade w/ LS400 AFM?
Guest
Posts: n/a
http://www.supras.nl/suprasport/cata...1f2a6e9d612cce
On a european supra site you can buy the LS400 AFM. Wonder why it's a performance part.
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
I had this setup on my 91 Turbo way back in 99. The Lexus AFM is a perf. upgrade because it flows more air than stock Supra AFM. Thus you need to also upgrade the stock Supra's injectors to 550cc to correct the air/fuel ratio. The bottom line is that now you can safely raise the boost up to 15-16PSI as opposed to stocks 9PSI or so.
Alternatively you can run a VPC/S-AFC combo but this will put a hole in you wallet.
Hope this help.
Hope this help.
VIPNiSS
05-02-22 08:48 AM
S2dannyKeo
Suspension and Brakes
08-20-12 01:42 PM
drft_n_sc
04-02-11 05:20 PM
