1997 LS400 Camshaft Position Sensor Problem
Hi there,
Last weekend I did my timing belt and water pump. I had trouble removing and reinstalling the right bank camshaft position sensor due to clearance problems with the Aisin water pump.
I must have damaged it because I got the code on startup. The car is running great but I want to replace it to get the codes clear.
1. Do I need to pull the timing belt again?
2. The car is running beautifully now but will it fail if that sensor is sending junk info to the computer?
3. How do you get that sucker in and out without busting it if the water pump is in the way?
Brian
Brian
Kimmytg
RX - 1st Gen (1999-2003)
10-13-17 04:52 PM
