Help!! Lol Sheered off idler pulley bolt
Old 02-26-14, 05:29 PM
  #46
timmy0tool
timmy0tool's Avatar
there is no baffle in the brake fluid reservoir but there is a screen in there and possibly a float connected to an indicator light telling you if you are low.
Old 02-27-14, 12:46 PM
  #47
Sewpra
Sewpra's Avatar
The E34 was 5spd so that make's sense Randal, thanks.
Also good to know about that brake reservoir screen and possible float as well.
Sent from my Nexus 4 using IB AutoGroup
Old 03-01-14, 04:30 PM
  #48
Sewpra
Sewpra's Avatar
Was a little worried about re-sealing the oil pump on the block/no.1 pan, without dropping the no.1, just to be safe I threw a hell of a lot of FIPG/Permatex Ultra Grey RTV on that side so it wouldn't slide off when I slid the pump housing on.
Old 03-01-14, 10:58 PM
  #49
Sewpra
Sewpra's Avatar
I'm disappointed about this... Lexus orders me the right bolt but, what in the hell? They still screw it up....
EDIT: Bolt in question is Idler pulley bolt/idler pulley no. 2 bolt in Toyota online documentation.
Attached Thumbnails Help!! Lol Sheered off idler pulley bolt-forumrunner_20140302_005823.png
Old 03-02-14, 06:38 PM
  #50
Sewpra
Sewpra's Avatar
If I could get a response from someone who is very knowledgeable with part #'s on these small parts or someone who has access to a knowledgeable parts desk employee because the guys at Lexus here clearly don't have a proper index or some other issue.
The part # for this incorrect bolt they ordered me is 90080-10313
I've also E-mailed Sewell parts to get help on the matter, I really don't want to have to take the bolt to a machine shop and get a custom job done on it, I'm looking at parts listings on LexusPartsNow and seeing as how this bolt is very close to being the right one, I'm seeing a similar PN in the subtree for Idler Pulley assemblee; BOLT, WASHER BASED H
Replaced by: 90080-10315 - Original PN - 90105-10248.
Old 03-02-14, 07:07 PM
  #51
LScowboyLS
LScowboyLS's Avatar
Looking at multiple different Lexus dealers online diagrams, this appear to be completely correct information, sounds like your local Lexus parts counter is staffed by Beavis & Butthead
Old 03-02-14, 07:19 PM
  #52
Sewpra
Sewpra's Avatar
Great! For future reference in similar matters Cowboy can you link me to these online diagram access points you speak of? My FSM doesn't state part numbers in the diagrams, just torque values.
Old 03-02-14, 07:40 PM
  #53
LScowboyLS
LScowboyLS's Avatar
well you could start with Sewell Lexus - it is probably the easiest to use.
Old 03-02-14, 07:53 PM
  #54
Sewpra
Sewpra's Avatar
I did try that at first, I'm able to search and pull up part #'s on there, but for some reason I can't find the link on the page anywhere to open these diagrams, I guess I need a dumbed down step by step navigation tree.
EDIT: Nevermind, I searched a different part number in that diagram on Sewell again and got the diagram on the results page, for some reason it wouldn't give me one before just by searching the bolt number.
Old 03-02-14, 08:19 PM
  #55
LScowboyLS
LScowboyLS's Avatar
their search is pretty bad - I do a lot better just flipping through the diagrams
Akshaan
02-08-17 08:08 AM
Tlkkens
RX - 1st Gen (1999-2003)
26
02-04-13 12:25 PM
WDoherty
Performance & Maintenance
01-08-11 04:06 PM
nismo2trd
18
04-06-07 05:42 PM
Eggman
23
01-06-07 10:54 AM
Quick Reply: Help!! Lol Sheered off idler pulley bolt
