Battle Version products or Megan?
Old 02-15-14, 05:27 PM
Lsd400
Lsd400's Avatar
Default Battle Version products or Megan?
Rear toe, traction, and camber links. Battle Version or Megan?
Old 02-15-14, 08:56 PM
Sc0pe
Sc0pe's Avatar
Battle Version is generally of higher quality, but Megan parts are more readily available, and wallet-friendly (as usual).
Old 02-16-14, 01:30 PM
Shmee
Shmee's Avatar
The Megan's don't really blow my socks off but the BV's certainly don't either...
I'm not sure how the JDM stuff commands the 3-5x prices they do considering how simple the designs are.
It sucks that we don't really have other affordable options.
The toe and trailing arms are not difficult to make, and a smart and resourceful person could probably make their own for less than $75-100 pair and a big case of beer for a little machine work.
The camber links could be done for about $150-200 and a couple cases of beer for the machine work.
The range in pricing is basically just the quality of the rod ends used. The likely generic PTFE rod ends used by BV being the cheaper price and better Aurora rod ends being the higher price. There is no crazy engineering involved in these arm, it's a straight compression/tension load which is pretty easy to design and build with basic knowledge. of the car in question.
Old 02-16-14, 11:05 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
in terms of traction (trailing/strut) rods and toe rods, it's a split difference. Price is comparable, BV May have a minor edge on quality.
for LCAs I would say BV, their design is actually somewhat different and I would buy them even with the price hit.
Old 02-17-14, 08:41 AM
Greg5OH
Greg5OH's Avatar
I have all BV rear arms in my 2000 ls. Previous owner put about 60,000 kms on them, still feel solid.
Old 02-17-14, 05:36 PM
timmy0tool
timmy0tool's Avatar
BV is far superior between the two. i've seen megan parts actually break at the welds, so if you live in areas that see road salt and snow do NOT get megan. BV is far better in quality (made in the US) vs china made megan. BV uses PTFE rod ends!
Old 02-17-14, 05:46 PM
Shmee
Shmee's Avatar
But BV probably uses PTFE rod ends made in China, so....
Old 02-17-14, 06:28 PM
timmy0tool
timmy0tool's Avatar
that's a possibility, but they are machined regardless vs welded in terms of ball joint connections. i am aware the BV lower arms are welded too.
pic from DebX:
Old 02-18-14, 11:58 AM
PureDrifter
BahHumBug
i haven't seen a megan arm break in years so idk where that's coming from
Old 02-18-14, 12:09 PM
Shmee
Shmee's Avatar
So much of the stuff you read/hear about part problems is incomplete info.
for a street car, the Megan's will give a nicer ride just based off the bushing design. spherical rod ends are not quiet; are very susceptible to road grime, dirt, and winter salt/chemicals; require a fair amount of maintenance where as rubber/poly bushings don't; and typically have anywhere from 1/20th to 1/2th the nomrla service life of a standard rubber/poly bushing; infinitely more precise with next to zero deflection and compliance. That last one is important if you are running an insane fitment and even a few mm of "put of desired plane travel," will result in some sort of impact of wheel/tire/fender/shock/etc with some sort of negative result.
the upside to the BV's i guess would be when the rod ends wear out, they are pretty easy to replace with better joints and dimensionally are pretty standard between brands/manufacturers.
Old 02-18-14, 01:02 PM
PureDrifter
BahHumBug
And Alex would probably sell you replacement bearings or tell you which ones to buy.
Old 02-18-14, 02:38 PM
racersky
racersky's Avatar
Have you tried looking at Serial Nine? I'm planning to purchase from them soon and they have a combo package with all three rear components for a decent price.
Old 02-18-14, 04:17 PM
PureDrifter
BahHumBug
serialnine is loved by the cressida guys i know, but they only seem to be making a couple parts for the UCF1x only, and have no pics up on their site .
Old 02-18-14, 06:51 PM
racersky
racersky's Avatar
Old 02-18-14, 07:00 PM
Shmee
Shmee's Avatar
UCF1x... I'm talking with them about the UCF2x stuff...
Quick Reply: Battle Version products or Megan?
