No electrical power whatsoever
Old 03-01-14, 01:10 PM
hvphotog
hvphotog's Avatar
Cool No electrical power whatsoever
Hi All,
I have a 1995 LS 400 which ran perfectly yesterday, parked it last night and went out today to start and nothing, not even a little bit of power anywhere. The car is completely dead, no lights, no sounds, nothing works at all. There was not hint of anything wrong last night.. just like dead weight today.
Any and all help would be greatly appreciated..
I already checked battery cables and they are tight and fine, will be testing battery for juice once my brother drops off my tester
Thanks
Chris
Old 03-01-14, 01:39 PM
LScowboyLS
LScowboyLS's Avatar
this will be an easy fix, either battery, battery connections or a main fuse or fusible link or ground strap
nothing else can cause a complete power loss
Old 03-01-14, 04:06 PM
hvphotog
hvphotog's Avatar
I checked the battery connections and they are ok
Where are the fusible links and the main fuse compartment on this car?
fairly new owner being this is my first lexus or Toyota.
Old 03-01-14, 05:54 PM
LScowboyLS
LScowboyLS's Avatar
fusible links and main fuses are next to battery in a big black box
additional small fuses (not the problem on your car) are near driver's left leg when sitting in car
Old 03-02-14, 05:49 AM
hvphotog
hvphotog's Avatar
Turns out battery was completely dead, now just have to figure out what drained it
Old 03-02-14, 09:42 AM
LScowboyLS
LScowboyLS's Avatar
my money is on the following scenario:
you have a power steering leak (20 year old car), the PS fluid has been dripping into the alternator for a while, and the alternator has not been charging the battery lately because the PS fluid ruined it.
this is extremely common on LS400, especially the year range you have!
Old 03-03-14, 06:45 AM
hvphotog
hvphotog's Avatar
There is nothing on the ground under where we park the car to indicate a leak of any type.. We did have a problem with the power antenna which i just took out the fuse for yesterday and thinking this was likely the problem, or my GF thinks she may have left the door ajar which would have left the light on.
Will find out today if one of those two are the culprits when i go to start the car today..lol
Tam4511
Performance & Maintenance
19
10-01-19 10:01 PM
Malihassan
CT 200h Model (2011-2017)
04-27-19 06:31 AM
aristonic
09-02-15 01:50 PM
semar
09-02-15 12:45 PM
Teahupoo
IS - 1st Gen (2001-2005)
12-18-11 06:55 AM
Quick Reply: No electrical power whatsoever
