Greetings from the caribbean!
Old 03-19-14, 07:50 AM
LScowboyLS
LScowboyLS's Avatar
make sure that the only solvent you use to clean the MAF is marked "MAF sensor cleaner" and for everyone else reading this, do not clean a pre-1995 MAF with any solvent! - not even MAF cleaner or "MAF-safe" cleaners
Old 03-19-14, 07:53 AM
LScowboyLS
LScowboyLS's Avatar
Originally Posted by zyzygy
Thanks for the info! it turns out that the maf isn't working, car runs rough with it connected or not
unless the car has been run without an air filter, which would be very strange on a car with 31,000 miles, then what makes you think the MAF is not working, that is not something that has issues on a 96 model
Old 03-19-14, 08:02 AM
zyzygy
zyzygy's Avatar
it gave 2 codes when connected to a scanner egr valve and maf, plus it runs rough with the maf connected or disconnected!
Old 03-19-14, 08:03 AM
zyzygy
zyzygy's Avatar
I'm also checking the maf wiring just to be cautious.
Old 03-19-14, 09:33 AM
LScowboyLS
LScowboyLS's Avatar
the LS400 has had some EGR issues, beginning with the crinkled section of the lower EGR pipe cracking
Old 03-19-14, 05:26 PM
zyzygy
zyzygy's Avatar
Turns out the efi fuse was out (car had a 2 channel amp piggibacked to the computer and was screwing everithing electrically) replaced it car is running perfect! Will pick it up tommorow to install stereo and a viper alarm! Will update as it progresses.
Soldier76
08-21-14 05:40 PM
LexusThang
01-23-10 02:37 PM
STIG
11-15-09 11:18 PM
Belmont
03-09-08 08:30 AM
GRAND_LS 4
15
07-03-07 10:21 PM
Quick Reply: Greetings from the caribbean!
