2000 LS new bushings in the rear, which ones?
#31
got new arms loaded with new BJ and bearings, all new knuckle bushings and tension rod bushings as well as sway bar links, as well as teh SPC press tool figs engineering showcased, ~600 bucks and then gotta move on to front bushings. oh well, she got 115k miles, first big bushing service. has new BJ and upper control arms up front already. as well as strut rod bushings. Not much left to do to make it all new!
#32
here are my new carrier bushings (i call it the camber arm). I do not need the smaller bushings (chassis side) so if anyone wants them 20$ plus the ride.
this tool is essential, or a similar low profile c clamp press. Thanks to Figs engineering for showing this is what we need.
used a 1" socket to press old one out, and a 27mm to press new one in. Its slightly larger than the bore opening, so once its bottomed you know the bushing is in there flat.
tension rod and camber arm bushings out.
my favourite for pressing them out. 3 seconds on the gun and its out.
hopefullly my sewel parts and tension rod bushings are in today or tomorrow and i can finish off this side, then start on the other!
#33
question about the bearing. its impossible to not get any crud in there while pullign the spindle off, so a few pieces of rust and dirt got in there. Its not a toally sealed unit, as in I can see the rollers. Im thinking to just spray it liberaly with brake clean, upside down, wait an hour for everything o evaporate, pick out any pieces of dirt with a dentist pick tha ti can see, and replentish some grease.
anythign wrong with that?
#36
also couldnt get the tension rod off the chassis. that bolt has become one with the inner sleeve of the bushing. That bushing had no play in it but you can see its old, the rubber has small cracks in it. Im going to leave this for another time, when i can get the car on a lift and sawzall the bolt out. Just no room around there right now, unless i pull the axles out of the diff and, no...just not doing that at this stage
#37
Well, considering you have the axel out of the knuckle and the knuckle on the floor... No it's not ON the car, it's quite obvious it's off or out of the car. Both of those bushings can be pressed out with the knuckle still attached to the car, keeping the axel in the knuckle and not exposing the bearing to debris.
That is what I meant by "on the car."
And sorry if that came off a little "****-ish", not how it was intended.
And just as a heads up, I'd probably start preparing to replace the wheel bearings on those rear knuckles. Separating the axel and knuckle on this type of bearing, with that sort of rust and as many miles and years as yours and the rest of our cars now have, can lead to accelerated bearing failure.
You might want to grad a set of rear bearings and do them at the same time as that seized bolt&bushing, since you are going to be in there again.... Up side is all new rear parts!!
#38
at first i didnt know u need a special tool to press those bushings out so thats why i pulled it off. But u have to pull it off anyhow to undo the bolt holding the UCA to the knuckle (slide the axle out).
Ill probably do the bearings and the seized bolt at the same time, perhaps in the fall. Then-100% all new parts!
#39
V8drummer
SC400 / 300 Classifieds
03-26-13 02:10 PM
stockhatch
Suspension and Brakes
14
12-17-10 01:40 PM
en11871
11-21-10 08:14 PM
