ls400 sputtering
Old 04-05-14, 07:58 AM
toyols400
toyols400's Avatar
Default ls400 sputtering
Good morning guys , i just bought a 1990 ls400 2 weeks ago ran like a champ
new tbelt,water pump,starter,plugs,wires ,new ecu sensor,coil, etc.. Just out of the
blues it almost die while stop at a red light. Now if i hit the gas it will suptter and smells
like gas, idle perfect, no misfire ,turns on perfect,trans shift perfect but i get code 34 already
changed the MAF same problem.
I know these is a old issue but i have read the forum i can't find anything else to do
please give me a hand to fix the problem i would hate to junk the car. Thanks
Old 04-05-14, 01:27 PM
YoshiMan
YoshiMan's Avatar
Did you swap it for another used MAF? or a rebuilt one? Perhaps the one you got is bad too?
Any other codes?
Old 04-05-14, 03:24 PM
LScowboyLS
LScowboyLS's Avatar
yes, it is very common for used '90-'94 AFM's (MAF) to be bad because many people mistakenly cleaned them with solvent or "MAF cleaner" over the years.
however, 34 is not a valid code for the engine, so could you download the codes again using this procedure?
Old 04-07-14, 04:15 AM
toyols400
toyols400's Avatar
Any other codes?
I sure did tested 2 MAF but I did check the ohm and test the same on all .
Old 04-07-14, 04:22 AM
toyols400
toyols400's Avatar
OK thank you Sorry my mistake code 24 is the right one.
Old 04-07-14, 04:33 AM
toyols400
toyols400's Avatar
My next procedures to check will be the following.
- fuel pressure regulator
- fuel pulsation valve
- fuel pump
- ECU (send it to get check) even do there's no signs of melted capacitors or damage on the board.
Thank you guys for your help !!
1302L
09-06-17 12:12 AM
1302L
09-05-17 11:56 PM
MuGGzyx
Performance & Maintenance
06-19-09 08:21 AM
snidehocke
02-05-08 04:51 PM
mikewu
01-12-08 10:02 PM
Quick Reply: ls400 sputtering
