Got 16" wheels for a 1990 LS400 - what to do about speedo?
So, finally I found my favorite wheels from a 1999 LS400 for my 1990 LS.
However, I just realized that wheel circumference on 225 60 R16 is much bigger than on 205 55 R15... so that will result in about 10% difference in speed.
However, 1993 and 1994 were also 1st gen, and they used 16" wheels, same tire size as 1999 LS. Should I adjust anything for the new tires? Just get my old speedo recalibrated? Or get a speedo from 1994 LS? I guess the wrong speed reading may influence how the engine works?
The car will be fine. You just have to remember the speed difference while driving. I did the exact same thing for my 92 with 98 wheels. If you go down to a 225 55 r16 the speedometer should be very close.
http://tire-size-conversion.com/tire-size-calculator/
and you're right, the difference is only 4% (don't know how I calculated 10% initially).
I have 225/55-16 on my '92, the stock size is 205/65-15, that is about 1% difference and neglictable.
It's only about 4%, and you should be fine. Try the tire size comparison calculator on the middle of this page to see the difference in odometer reading etc :-)
Well when im cruising at 95 which is 10 over the limit, its acceptable. but I want to know if my speedo reads 95 what am I really doing? its one thing to speed on purpose but no cop believes the tires size story
dang these cars change everything from year to year dont they? but that helps. Less worry about that then. too many cameras out here to risk it
