No spark on driver side plugs
Old 04-28-14, 09:46 PM
aptoslexus
aptoslexus's Avatar
Originally Posted by Yamae
It only makes sense when the secondary voltage is not high enough. It requires only 1kV to travel electrons for a 1mm gap at ambient. But in the compressed air such as at 10 ATM, more than 10 kV is needed to have a good spark. Did you check the leakage?
I'm no electrician, but looking at this diagram, it still doesn't make sense. Seems like each distributor is feeding both banks, which means both coils and igniters are doing the same. How can one bank be out?
Old 04-29-14, 06:16 AM
python
python's Avatar
I would check the crank sensor.
also unplug 1 coil,see if the engine starts up...if it does plug it back in and then do the other coil. I know u changed them but maybe u got a bad one. my car had an intermittent misfire at idle, turned out to be one of the coils was barely out of spec on the secondary ohm reading...changed it,car ran fine
Old 04-29-14, 11:48 AM
kohatsu
kohatsu's Avatar
ill talk to the mechanic to check on it thanks
is3504bao
09-23-22 11:01 AM
LexBrett
07-29-15 02:21 PM
cgawelko
13
04-23-15 05:51 PM
Quick Reply: No spark on driver side plugs
